| | #1 |
| Registered User New Member | I want to round over the edge of a 1/2" thick piece with a Bullnose type bit. I figure that it'll produce a nice even rounding of the edge. However the piece is not straight. It has "s" curves and 180 degree turns that make it impossible to use a table fence. At least I think so. What's the best way to successfully round over the edge of my project piece? I'd like to use the Bull nose bit but if there's a different method I'm open to suggestions. Thanks in advance. Wildhorse |
| | #2 |
| Forum Contributer Supreme Forum King | HI Wildhorse How about a cove bit with a bearing on it .. ===========
| | #3 |
| Registered User Forum Geek | Bob is correct (as usual). Use a bearing with the correct offset that you need. The router will follow the wood. No corners- you would need to use some hand tools for the close spaces. -Derek |
| | #4 |
| Forum Contributer Supreme Forum King | I can't see why a bullnose cutter in a small based router couldn't be used, if the inside curve is too tight just approach from the rear, just make sure that the cutter is dead on centre of the thickness and you shouldn't see the crossover points. A piece of scrap needs to be screwed to the router base to be kept tight against the rear of the workpiece and remember that with a bullnose cutter you can't lift the router, it must be slid back to the end. You could of course use the same method using a roundover cutter adjusting it accurately on a test piece and the router can of course be lifted.
__________________ Harry Last edited by harrysin; 06-05-2008 at 08:50 AM. |
| | #5 |
| Registered User New Member | Thanks for the responce. However, a cove bit would cut the exact opposite profile I'm looking for. I could use a roundover bit and flip the piece but that can result in the profile being off center. Wildhorse. |
| | #6 |
| Forum Contributer Supreme Forum King | Hi Wildhorse Sorry I did say cove but I meant bull nose with a bearing.. Bull Nose Router Bits (w/ ball bearing guides) http://www.mlcswoodworking.com/shops...Bearing_Anchor =========
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 06-05-2008 at 10:32 AM. |
| | #7 |
| Registered User New Member | Thanks again for the quick response. Just wondering where I can get a bull nose bit with a bearing. I have 2 bull nose bits with 1/2" shafts and neither have a bearing or a place for one. Is there a device like a mandrel that will accomodate a bull nose insert with space for a bearing? If so where can I get one? Wildhorse. |
| | #8 |
| | #9 |
| Registered User Forum Fanatic | You could also use a template guide bushing with your current bull nose bit. |
| | #10 |
| Registered User New Member | Thanks to both Charles and Bob. Of course my wife is going to leave me if I buy one more router bit. Hey, maybe if I finally made something for her...do ya think? Guess we're gonna find out. I'm going to give both methods a try. It's exactly for this reason that I joined this forum. Expert suggestions/help freely given. SUPER!!! Wildhorse |
| Freehand routing | Visteonguy | General Routing | 50 | 09-08-2008 01:26 AM |
| Routing Template | Verlin Garrett | Jigs and Fixtures | 5 | 02-06-2006 04:43 PM |
| Curved Groove Routing ? | Jackalope | Jigs and Fixtures | 4 | 03-10-2005 04:29 PM |
| routing curved edges on a router table | John B | General Routing | 3 | 01-14-2005 11:50 AM |
| Routing end grain | Pop_pop1 | Table-mounted Routing | 8 | 09-22-2004 01:24 PM |
