| | #1 |
| Registered User New Member | I need to route holes in a fence post to accept the rails of some vinyl fencing. The posts are 4x4, and the holes will be 2x3 to accept the vinyl rails. The holes don't need to go all the way through but need to be deep enough to hold the rails. There are 3 rails for each post so I'll be making quite a few holes (11 posts). What type of bit and how could I make some kind of template/jig for this? I have a craftsmen plunge router and a porter cable fixed base. |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi OhBrian I would suggest making/using a saddle jig ,see below... ======== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 07-02-2008 at 05:56 PM. | |
| | #3 |
| Registered User New Member | Never would have thought of doing that. Thanks a bunch! |
| | #4 | |
| Forum Contributer Supreme Forum King | You'er Welcome OhBrian It should should get the job done in quick order.. ========== Quote:
| | #5 |
| Senior Moderator Supreme Forum King | Brian, The method BJ suggested is the way to go. I would build the jig with all 3 openings so the spacing stays perfect. Measure a line off the ground on the center post for where the top of the jig will be mounted. Use a level and a chaulk line to transfer the location to the other posts. This shouold give you a perfectly balanced fence.
| | #6 |
| Registered User New Member | Another excellent idea Mike. What kind of bit would be best suited for this? I see my problem now will be cutting a smoot opeining in the first piece for the template/jig. |
| | #7 |
| Forum Contributer Supreme Forum King | Hi OhBrian Just a butt in post,, ![]() Forstner Bit or hole saw will get the job done for the template hole.. See the guide chart to select the right size hole.. A compass works well for the job..I would suggest a 3/4' GUIDE with a 1/2" bit. For the bit I would use a SOLID MICRO-GRAIN CARBIDE Bit for fast, smooth cuts and an edge that stays sharp longer. Spiral Bits produce a very clean and accurate cut with minimal chatter. With a vac. pickup on the router base to pull the chips out and away from the hole. http://www.mlcswoodworking.com/shops...ter_set_anchor ==========
| | #8 |
| Registered User Supreme Forum King | You could use the forstner bit to get most of the wood cut out, then clean it up with the router. That would save the router bit from doing all the work.
__________________ Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ |
| Forum Rules and Usage - Read this before you post! | Mark | Wood Scrolling | 0 | 08-26-2006 05:57 AM |
| Face Lift for the Router Fence | bobj3 | Jigs and Fixtures | 7 | 06-05-2006 09:57 AM |
| Some Thoughts on Fence Control | Gilbear | Table-mounted Routing | 5 | 12-20-2005 06:38 PM |
| Forum Rules and Usage - Read this before you post | Mark | Lobby | 0 | 09-11-2004 12:51 AM |
| Forum Rules and Usage - Read this before you post | Mark | Introductions | 0 | 09-10-2004 08:11 PM |
