| | #1 |
| Registered User Dedicated Member | Could anyone let me know where I could find info on how to set router bits up? I just got my router bits from holbren a few days ago, and was fooling around with my raised panel set last night. They cut well, however, it took a lot of messin around to get them somewhat close to being a matching rail and style (to where the tops were flush). Is there somplace that lists a quicker way or simple way of doing this (other than setting up scrap pieces to refer back to)? Not just with rail and style sets, but others, as well? I guess I should probably just go by a router book, eh? Thanks! Last edited by saltysteele; 02-17-2005 at 12:15 PM. |
| | #2 | |
| The Router Guys Forum King | Quote:
Example: Quick guideline and overview to the set up of your cutters. (A) use a 1/8" piece of plywood to determine the height of the cope cutter. Set 1/8" plywood under the cope cutter as identified on photo and lower into position on the plywood. Lock router bit into position and remove the plywood. With a fence: isolate your bearing, lock fence, support the cope pieces and cut the cope. (B) The bead cut, set the height of the bead cutter by matching the slot cutter to the tenon on the cope. See photo marked as (B) With a fence: isolate the bearing, lock fence and cut the bead. (C) the panel cutter is the last operation. With a fence: isolate the bearing, lock fence and set the height of the bit to match "what's left over to the thickness of the groove of the bead cut." Remember The thickness of the panel will determine the position of the cutter height. After cutting the panel what's left over has to fit into the groove made by the bead cut. That's it... be safe and always use a proper fence and push sticks. Good Luck and keep your fingers away from moving router bits.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. Last edited by BobandRick; 02-17-2005 at 02:48 PM. | |
| | #3 |
| Registered User Dedicated Member | I would be very much interested in a site like that. I know no question is a "dumb" question, but after a question is asked a different way 300 times, doesn't it start to get silly? ![]() I think a site like that would be very helpful to us that are just starting out, and maybe to those that need refreshers. It would be like being able to watch the router workshop anytime of the day (well, as far as pointers, tips and stuff like that). Thanks for your tips on how to set up the cutters! I'm not going to be able to get out there today, but I'll be trying it tomorrow! I could be back with questions ![]() |
| | #4 | |
| Forum Moderator Supreme Forum King | Quote:
Do it guys! We love ya!
__________________ Cheers, Bob | |
| | #5 | |
Make sure to use a fence and keep safe. On the website, we are building as we speak...sorry can't give out the url yet.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| | #6 |
| Registered User Dedicated Member | Sweetness, can't wait. Not to rush, but do you have a timeframe? Thanks, guys! I love this site. For instance, the post about the spiral bits, up vs down. Never would have thought of the points that were made in that post. I probably would have just used the wrong bit, gotten angry and never figured it out. Ain't learnin fun? Last edited by saltysteele; 02-17-2005 at 09:36 PM. |
| Oak Park Mitre Gauge - Need Setup Help.. | Chris H | Jigs and Fixtures | 3 | 07-06-2008 11:39 PM |
| Bosch Ogee Rail and Stile Bit Set setup? | gxbluewave | Table-mounted Routing | 1 | 01-07-2008 10:45 PM |
| Permanent Dado Setup | arkwood | General Routing | 3 | 05-22-2007 11:06 PM |
| Using brass setup bars | Blind Bruce | Table-mounted Routing | 4 | 12-30-2006 04:09 PM |
| Stile and Rail setup? | fitz | Jigs and Fixtures | 1 | 03-26-2005 08:53 AM |
