| | #11 |
| Registered User Forum Fanatic | When I cut the mortices with a router then decide not to square them up, I make the tenons to finish size then saw each corner at 45° then chisel to these saw cuts. The sides and top of the tenons match the mortices and the gaps between the tenon radiuses and the chamfered corners allows the trapped glue to escape. I've never had any problem with weak joints doing it this way.
__________________ Dewy support team at Paltalk voice chat program |
| | #12 |
| Senior Moderator Supreme Forum King | One other way to consider is to use pocket hole joinery. Using glue and pocket hole screws is actually stronger than a mortise and tenon joint. Take a look at the Kreg jig and give it some thought. I like using mine.
| | #13 |
| Registered User Member | Yeah, I contemplated using pocket hole joinery in conjunction with dowels but didn't think it would stand up as well as a pinned tennon and mortise joint. I first saw a pocket hole joint at a woodworking show a couple years ago and thought it was the coolest thing I ever saw, but never explored it further.
__________________ Just a big kid.. |
| | #14 |
| Registered User Forum Geek | Simply use a round over bit. use a bit that matches the radius of the mortises. regards jerry |
| | #15 | |
| Registered User Member | Quote:
It just amazes me to see all the tenons in a book I just bought have perfectly rounded edges, but they don't explain how they got them. I have two books coming from Amazon.ca, "Router Magic" and "Woodworking With The Router", and I'm hoping that either or both have good joinery sections.. specifically on mortises and tenons. Christopher.
__________________ Just a big kid.. | |
| | #16 |
| Senior Moderator Supreme Forum King | Christopher, you can make rounded tenons of limited length with your router. This requires buying or building a tenoning adapter. To be honest, neither is really cost effective in my opinion. Unless you are going into full time production of furniture you are far better off investing your money in other tools.
| | #17 | |
| Registered User Forum King | Quote:
Please let me know Tom | |
| | #18 | |
The <img> tags point to files on your hard drive, not to files on the web server. Sadly, the page is effectively still broken. ![]()
| | #19 | |
| Registered User Sr. Member | Quote:
Depending on the thickness of the stock of the tenon you can use a half round bit. Some mfgs. have other names for this bit. But they all do the same thing..............that;s put a half round on the edge of the stock. But like the comments in the other postings, you don't have to riund them off because they don't show. ADDED: If you don't have it I recommend "The New Router Handbook" by Patrick Spielman. It was written in 1993 so some of the routers won't look the same as they do now but it's the best book on routers and how they can be used I've found yet. It's worthwhile checking into. Last edited by DONALD; 02-28-2005 at 11:35 AM. | |
| | #20 |
| Registered User Member | I received my two books from amazon.ca this morning, the first being "Woodworking With The Router" and "Router Magic". I quickly dove into the tenoning sections of each book and found one method I think I really like, use a rasp or coarse file to round off the corners. My fears with the chisel is if you made a bad cut, you could end up taking too much off leaving the tenon too loose in the mortise. By using a rasp or file, you remove the squared off corners gradually and have more control over the rounding process. I think that's the method I'm going to employ. ![]()
| Tenons on the Router Table | rstermer | Table-mounted Routing | 12 | 04-24-2008 10:41 AM |
| Rounded Mortise & Squared Tenons? | Nickbee | Table-mounted Routing | 15 | 01-16-2008 09:11 PM |
| Tenons | JDługosz | Jigs and Fixtures | 1 | 10-21-2007 04:13 AM |
| How would a raised rounded edge like this be produced? | paulcomi | General Routing | 1 | 08-14-2006 03:04 PM |
| What bit do I use for cutting tenons | Johnny Dee | Tools and Woodworking | 4 | 02-07-2005 02:32 PM |
