| | #1 |
| Registered User New Member | I bouhgt a rockler dovetail jig, looks simple enough to use however it appears to be for blind dovetails. What's the difference in the jig for through vs blind joints?? Do I need to buy another comb for through dovetails?? TIF Wayne |
| | #2 |
| Senior Moderator Supreme Forum King | The answer is yes Wayne. It takes a different template for the through dovetails. Price out the additional template, add it to what you spent and see if it would be cheaper to return what you bought and buy the set with both included. Make sure when you load your board to be dovetailed that you have a board of equal thickness on the opposite edge of the clamp. This is true of both the front and top clamps. You need the support so the clamp applies even pressure.
__________________ Mike |
| | #3 |
| Registered User Forum Fanatic | mike here is a question along the same lines of what you just mentioned, i have a dovetail jig as well but i am very unclear on how the correct set up should be. i realize that you need to off set one of the boards so the teeth will lock into place but how far do you offset them and which board do you move? the vertical board or the board that lays on top. what is the best way to make sure the wood is in the jig clamps perfectly, as in not at an angle but a true 90????? yo usee what im getting at??? shawn |
| | #4 |
| Senior Moderator Supreme Forum King | Shawn, this is really tough for me to answer since all the different brands of jigs are set up differently. Dovetails are not my strong suit either. In general the amount of your offset should equal the diameter of your dovetail bit. This is assuming you are going for equal size, equal spaced dovetails. Your jig should have a 90 degree reference mark or guide of some kind on it. The vertical board should be a good enough reference to square off of. I guess for anyone to give you the correct answer they will need to know the brand of jig you have. If you are not sure, post a photo of it. Sorry I can't be of more help on this one.
| | #5 | |
| Registered User Dedicated Member | Quote:
Jeff Last edited by jeff12002; 03-02-2005 at 12:53 PM. Reason: I missed something in my original response | |
| Dovetails - more or less - opinion | Donzoid | General Routing | 4 | 11-27-2007 01:02 PM |
| Incra jig and rabbeted half blind dovetails | S Bolton | Jigs and Fixtures | 10 | 08-24-2007 01:06 PM |
| Sliding dovetails for cabinet constuction? | Drugstore Cowboy | Tools and Woodworking | 18 | 07-08-2007 04:14 PM |
| Blind Dovetails | challagan | Jigs and Fixtures | 17 | 12-23-2006 01:40 PM |
| Questions about Dovetails | fibertech | Jigs and Fixtures | 2 | 07-06-2005 08:37 AM |
