Thread Tools Display Modes
Old 03-01-2005, 12:05 PM   #1
jamin1
New Member
jamin1 is on a distinguished road
Default 1/4 or 1/2 Shank?
I am in the process of building a router table and will be purchasing some new bits for my collection. Is their a difference in performance, length of usage, etc between a 1/4 or 1/2 shank? Is it worth the additional cost to go with the 1/2?
jamin1 is offline   Top - Reply with Quote
Old 03-01-2005, 01:26 PM   #2
Learning Herb
Forum Fanatic
Learning Herb's Avatar
Learning Herb is on a distinguished road
Yes , and they don't really cost that muct more,I use 1/2" when ever posable.O,K,
Learning Herb
I try to learn some thing new each and every day ,
Learning Herb
Learning Herb is offline   Top - Reply with Quote
Old 03-01-2005, 09:06 PM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
1/2" shank bits are stronger and have less vibration than 1/4" bits. Cost is usually about the same. Make sure you get a decent quality bit, the few extra dollars will save lots of heartache later.
Mike is online now   Top - Reply with Quote
Old 03-01-2005, 09:57 PM   #4
hcbph
Dedicated Member
hcbph is on a distinguished road
Who says you can't have both? Bosch, PC and a whole lot of others have both 1/4" and 1/2" collets for them. In fact I also have an 8mm for my Bosch plunge router. On average, the thicker the shank the better. Less vibration & chatter while cutting.
hcbph is offline   Top - Reply with Quote
Old 03-02-2005, 08:20 AM   #5
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi Jamin: most people have both 1/2" and 1/4" bits, because the bigger shank cuts vibration and usually gives a better cut. However, bits that are used to shape edges
and take light cuts can be easily done with the 1/4" bits. When you use big bits
like those used to cut rails and stiles for doors and raise panels you use 1/2" bits and slow down the router speed. These bits remove a lot of material, and absolutely should be 1/2", 1/4 " bits if they are made in those sizes should not even be bought because they are dangerous. As to quality, cheap bits cost more because you will have to replace them when they fail. I suggest you buy the best that you can afford
good bits last a long time and will take sharpening more times in thier life.
Hope this helps...Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Metric shank sizes? Gusbub Router Bits - Types and Usage 16 02-12-2008 11:02 AM
Rail & Stile 1/4" shank? Drugstore Cowboy Router Bits - Types and Usage 5 05-24-2007 12:14 AM
1/4" Long Shank Foxtail General Routing 2 11-07-2005 09:08 AM
long shank router bits Birchwood General Routing 3 08-10-2005 04:13 PM
3/4" Radius roundover bit with 1/4" shank chrisogrady General Routing 8 04-01-2005 09:08 PM
