| | #1 |
| Registered User Member | Plastic is used for baseplates, fences, and a lot of things in connection with routers. What is the best kind of plastic to use for the different applications? How thick should it be? I am thinking about buying a Porter Cable 7518. What would be the best baseplate material for mounting it in a table? |
| | #2 |
| Senior Moderator Supreme Forum King | Phenolic is the material of choice for mounting plates, or aluminum. Either way 1/4" is the thickness you are looking for. Both will flex a bit with a 7518. I am mounting my 7518 on a Rousseau plate for easy swapping in my tables. The Rousseau plate has a built in curve to the top surface that flatens out with the weight of a router. Add to this the ability to mount guide bushings in the center, easy opening size changes, the safety pin, corner snuggers and levelers. The $44.95 price tag from Woodcraft is very reasonable for this well thought out design.
| | #3 |
| Registered User Forum Geek | If you use phenolic use 3/8". You don't want an insert to "flex".I have had a PC 7518 hanging from a 3/8" phenolic insert for years with no sag. I also have tables with Woodpecker aluminum plates and don't measure any sag (flex,deflection) in any of them. The 7518 is a locomotive you will be happy with it. Good Luck Jerry |
| I can't get Avery labels to stick to plastic container | S Bolton | General Routing | 25 | 10-19-2007 10:03 AM |
| glue for plastic laminate | S Bolton | Table-mounted Routing | 8 | 09-29-2007 01:05 PM |
| Machining UHMW plastic | pmspirito | Tools and Woodworking | 2 | 09-05-2005 09:41 AM |
| Plastic router fencing material | mstevensjr | General Routing | 6 | 09-02-2005 04:28 PM |
| What Router to buy (cutting plastic) | stevegriswold | General Routing | 1 | 07-03-2005 01:56 PM |
