Thread Tools Display Modes
Old 03-07-2005, 01:00 PM   #1
zxxer12
New Member
zxxer12 is on a distinguished road
Default routing small pieces
What's the best technique for routing small pieces??
I want to cut some slots and counterbores in small pieces which are difficult to clamp to the bench due to the small size.
The stops shown are about 6"x6"
TIA
zxxer12 is offline   Top - Reply with Quote
Old 03-08-2005, 10:39 AM   #2
dustmaster
Dedicated Member
dustmaster's Avatar
dustmaster is on a distinguished road
My suggestion would be to nail or screw the suckers to a bigger piece.
dustmaster is offline   Top - Reply with Quote
Old 03-08-2005, 04:21 PM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
ZXXer12, You can make jigs for each of your small pieces, but the precision method would be to use a pin router and a machinists vice that has screws for movement similar to the way a milling machine table works.
Old 03-08-2005, 06:11 PM   #4
template tom
Forum King
How large (small) are the pieces to be cut?
Tom
Old 03-08-2005, 08:09 PM   #5
zxxer12
New Member
Default Small pieces
Each item shown in the sketch above is ~6"x6".
Since i'm going to make at least two I thought I'd leave them together, cut the slots and then seperate. That way the whole pice would be ~12 long by 6" wide.
Thanks all.
Old 03-09-2005, 07:24 AM   #6
JamesEMc
Forum King
JamesEMc's Avatar
JamesEMc is on a distinguished road
I'm not certain what you mean by counter-bore, but each piece has two screw holes that could be used to attach them to a bench. Then clamp pieces of equal-thickness wood beside them to balance the router. Routing first then cutting would make sense, too.
Reunite Gondwanaland
JamesEMc is offline   Top - Reply with Quote
Old 03-09-2005, 04:51 PM   #7
template tom
Forum King
The sizes you are quoting are certainly not small pieces by any means. for example I have produced recessed handles which are only 100mm long and 40mm wide. This does require a means of holding the material secure during the process and I have made a Jig holder to hold material and the template required to control the cutter. You will require to have some knowledge on the use of the template Guides (Guide bushes)
Tom
Tom
Old 03-09-2005, 04:55 PM   #8
template tom
Forum King
Sorry,
I should have included a pic.
Tom
Old 03-21-2005, 04:37 PM   #9
TomB
Jr. Member
TomB is on a distinguished road
Work the opposite way round. Your method of working is to cut down to a small size first then rout it. Dont. Rout first then cut the pieces down. A simple explanation is as follows.
IF you couldnt buy 1/2inch scotia moulding in 8foot lengths and HAD to make it you would not cut a piece of timber 1/2 x 1/2 and then rout it because it is difficult to do and dangerous. What you would do is take a piece of 6inch x 1/2" (six inch wide is easy to clamp or screw/nail to a bench) rout the moulding and then put the timber through the table saw. Simple and quick, its how I do non standard mouldings on site.
PS forgive the spelling of moldings
TomB is offline   Top - Reply with Quote
Old 03-21-2005, 04:40 PM   #10
TomB
Jr. Member
PS my version is the other side of the coin to dustmasters post, make a small problem big
small pieces fishlore Table-mounted Routing 58 11-21-2007 08:23 PM
Cutting very small pieces on table saw simplenik Tools and Woodworking 13 08-16-2007 07:10 PM
Advanced (?) Template Routing billdcon Jigs and Fixtures 6 03-09-2005 01:07 PM
Hinges, locks on small pieces? Densa Jigs and Fixtures 4 01-27-2005 01:23 AM
1/2 lap on small pieces? Densa Jigs and Fixtures 4 01-26-2005 11:32 AM
