| | #1 |
| Registered User New Member | Ok, so I bought a rail and stile bit set and the results of my first attempts were pretty bad. What's a good wood to practice on? A wood that minimizes wear and tear on my bits. tauras |
| | #2 |
| Forum Contributer Supreme Forum King | HI tauras I would suggest some Poplar ![]() It's one of the cheaper woods and will hold the edge. =====
| | #3 |
| Forum Contributer Supreme Forum King | Here in Australia I use cheap pine and still have quite a few rails and stiles that didn't turn out quite right, but no great cost was involved. I just keep them to remind me not to make the same mistakes next time!
__________________ Harry |
| | #4 |
| Registered User Member | I find the best wood to practice on is what you can find in the streets on the eve of garbage day.... this way you can try different settings, feeding speed, grain direction and whatnot. But since every type of wood will produce fairly different results, if you always practice on say pine and then want to use your bits on blackbutt you may have some few suprises. Since I am only new at this and get really cranky if I ruin a nice and expensive piece of wood, here's what I did to teach myself how to use those bits: I used the woods that are the most well known for being prone to chipping easily when routed and exercised on that. When I was able to rout descent groves and so on on this type of wood without chipping then I could consider myself able to rout those more expensive pieces of wood without having the shakes as soon as I switch on the router. I found Tassie Oak and Oregon are example of wood (along with crapy pine and pallet woods) that chip easily so good for practice. Mind you, I still stuff up more often than I should !!!! ... and each time I do it's because I am too much in a hurry to see the result and make too deep passes. Cheers S. |
| | #5 |
| Registered User Supreme Forum King | Hi, If you're worried about price, the best wood would be.... "dumpster diving" at an area building site. Pending on where you're located and if you're going to purchase said wood, Poplar is really the best choice. While I'm not going to disagree with Harry about Pine, because it's another nice type to work with. Pine, however, is "sappy", this tends to gull up bits, it's the major draw back to Pine.
__________________ Ken "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #6 | |
| Registered User Dedicated Member | Quote:
| | #7 |
| Forum Contributer Supreme Forum King | "Is oven cleaner as effective at cleaning them as I've heard?" I've never tried or even heard of that one, I use whatever solvent is handy at the time, petrol, turps.,thinners etc.
| | #8 |
| Registered User Supreme Forum King Join Date: Nov 2006 Location: Fort Worth,Texas USA First Name: George Posts: 1,588 ![]() | Oven cleaner will work. You just have to be very careful handling it. It is very caustic. You know... rubber gloves, don't inhale it, all that kind of stuff.
__________________ George For those who haven't already done so... PLEASE! PLEASE! Fill in your first name and location in your profile. |
| | #9 | |
http://woodworking.about.com/od/blad...ovingPitch.htm An alternative POV here: http://www.toolcrib.com/blog/2008/07...d-router-bits/ I was surprised at tje suggestion, not very surprised that it might work: one of the books[1] I read as a teenager described how to dissolve meat in caustic soda solution. It was a chemistry book, not a Robin Cook novel.
__________________ John | |
| | #10 | |
| Forum Contributer Supreme Forum King | Quote:
I'm surprised that an established routing expert who has published several books on routing, like Patrik Spielman would suggest such dangerous chemicals around our workshops.
__________________ Harry | |
| Perfect 22.5 degree miter | Kristin D | Tools and Woodworking | 11 | 02-26-2008 06:59 PM |
| Who Makes an Offset Trim Router??? | garycurtis | General Routing | 19 | 09-30-2007 11:59 PM |
| Perfect box joints | Router is still my name | Show N' Tell | 0 | 09-16-2006 09:23 PM |
