Help
Go Back   Router Forums > Routers > Guide Bushings and Templates
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the largest router and woodworking community on the web! Join in over 20,000 discussions with over 40,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Making a guidebushing baseplate
This is a discussion on Making a guidebushing baseplate within the Guide Bushings and Templates forums, part of the Routers category; Hello again, I just read through the guide bushing pdf by template tom (hope I ...
Old 11-26-2008, 03:01 PM   #1 (permalink)
loninappleton is on a distinguished road
Default Making a guidebushing baseplate
Report Post Report This Post!
Hello again,
I just read through the guide bushing pdf by template tom (hope I got that right) and then looked for the what is needed to actually use some guide bushings.
The Craftsman router I got has a smooth baseplate and doesn't appear to have any machining for the guides.
Now comes the part where I need a comparison list of what brand router
guide bushing base plates are compatible with this and in the US. (Truthfully, I didn't check for this add-on at time of purchase but it is not shown in the accessory list in the manual.
The Craftsman model number is 9.5 amp 1 3/4 Peak HP Fixed Base Router
Model No. 320.17541
But I actually have a different question. I was wondering if a guide bushing baseplate can be made for a palm router and equivalent small tools like the Rotozip. How to get the centering right and make the seat for the
bushing is what I'd like to find out.
Unfortunately these questions/details seem to be skipped over in the books I've seen.
I have a rotozip kit from a different manufacturer and a variety of bases are supplied. These include the laminate trimmer attachment. This add on
has a square removable baseplate with 4 screws.
Also I got some plexiglass scrap from the local plate glass installer. Perhaps
a couple sheets of that could be layered with the right size cutout made
with a hole saw? I have a number of those hole saws including a 1 inch OD from the big box store. I don't know if getting the right dimension to do this would be a big job or an easy job.
The funny thing is that after I got the Sears I'm trying to figure out more uses for the zip tool it was going to replace.
loninappleton is offline
Old 11-26-2008, 04:33 PM   #2 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi loninappleton
this is just one of many ways
It's a very easy job to do, you just need two forstner bits ( 1 3/16" and a 1 3/8" ) and a drill press..
The easy way is to clamp the 1/4" thick plastic to the drill press, the base plates can be any size you want to make them..
Put on some masking tape on the plastic,draw out a square of the size you want then draw a line from corner, now you have a " X " in the center,now chuck up a 1/8" drill bit and move the plastic under the drill bit so it will hit the " X " dead center now clamp the plastic down to the drill press table with some scrap under it.. once you have it clamped down drill the 1/8" hole then remove the drill bit and chuck up the 1 3/8" bit and drill down about 1/8" deep, once you have the down chuck up the 1 3/16" bit and drill out the hole, b/4 you un clamp it check to make sure the guide will pop in the hole and sit flat...
Once you have that done pull off the old base plate and use it for a template to drill the mounting holes, use masking tape to hole it down to the plastic make sure it can't move then drill the mounting holes.
Use the brass guide to line up the new plate with the old plate ..
hope his helps
Originally Posted by loninappleton View Post
Hello again,
Model No. 320.17541
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
How to Remove and Reinstall a Drill Press Chuck
See all 48 videos, Great tips.
http://www.youtube.com/watch?v=KbI_7...=31&playnext=3
HOW TO Inset a Router Base Plate
http://www.popularwoodworking.com/ar...e_plate_video/
Wood Working Videos, many great ones.
http://web.me.com/deceiver6/Deceiver/wwvideos.html
Router Tables
Router Tables Made Easy, with this video.
http://www.sommerfeldtools.com/Route...ductinfo/DVD3/
http://www.youtube.com/watch?v=sFW5gBYwt4M
http://www.youtube.com/watch?v=QjW5H...eature=channel
Old 11-26-2008, 04:40 PM   #3 (permalink)
nickao65's Avatar
First Name: Nick
nickao65 will become famous soon enough
Can't he just pull the base plate he has and drill that? Of course the opening has to be small enough to begin with.
nickao65 is offline
Sponsored Advertisements. Register to disable this advertisement.
Old 11-26-2008, 04:57 PM   #4 (permalink)
bobj3's Avatar
Hi Nick
You bet the one on the Craftsman but not the rotozip...like many of the small tools it has a odd size hole and setup..but it's not a big jump to make a new one for the Craftsman once he has made one..and square is always better than round..
Part Finder
Router Tables
Old 11-26-2008, 07:05 PM   #5 (permalink)
Thanks for responding.
The forstner bit and drill press idea is a good one. It would get things centered
accurately.
I know a guy with a drill press. Less sure about where to cadge some Forstner bits that large.
10% OFF at Rockler.com!
Old 11-26-2008, 07:46 PM   #6 (permalink)
bobj3's Avatar
Hi loninappleton
You may want to think about using the bigger brass guides,, 1 1/2" type, the forstner bits are a bit essayer to find for that size.. it takes a 1 1/2" and a 1 3/4" ones.
http://www.leevalley.com/wood/page.a...000,51208&ap=1
forstner bits ▼
The hard one to find is the 1 3/16" one and it's must have item..
http://search.harborfreight.com/cpis...bits&Submit=Go
http://shop.ebay.com/?_from=R40&_trk...All-Categories
http://cgi.ebay.com/NEW-1-3-16-FORST...3A1|240%3A1318
accurately.
Part Finder
Router Tables
Old 11-26-2008, 09:26 PM   #7 (permalink)
Lots to think on here.
thx
I will come back in this thread when I've made some progress.
Shop now at Tool King!
Old 11-26-2008, 09:57 PM   #8 (permalink)
RustyW's Avatar
First Name: Rusty
RustyW will become famous soon enough
I can't believe its been over a year since I posted this. But here's how I make them, maybe it will help. I drilled my thru hole 1 1/4" because I don't have 1 3/16" bit. The rim on the bushing fits snug in the recess so there has'nt been any problems. Only thing I do different now is counter bore, rather than counter sink the mounting holes. Sometimes the guide needs to be perfectly centered and this allows for some adjusting.
http://www.routerforums.com/guide-bu...pc-guides.html
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
Old 11-26-2008, 11:09 PM   #9 (permalink)
I have enough tips going now to take me through til Spring.
Shop now at Rockler.com!
Old 11-27-2008, 12:18 AM   #10 (permalink)
Mike will become famous soon enough
Reading the sticky threads would of answered your questions. Brian and I made a base plate for his Craftsman and posted photos of how we did it. Threads are made into sticky threads when they have important information. http://www.routerforums.com/73038-post1.html
Wooden sign making tigger Sign Making 6 08-25-2010 07:29 PM
Making a vase part 1 chippypah Woodturning and Lathes 0 03-04-2008 02:23 AM
Mounting Bosch Jigsaw to Router Baseplate - finished Ladd Table-mounted Routing 4 02-06-2008 05:47 PM
template making wood reds_21 Tools and Woodworking 3 07-10-2005 08:45 AM
Oak-Park baseplate for PC7518 Drick Table-mounted Routing 2 05-19-2005 05:09 PM
