Inlay Chart/Update - Router Forums
post #1 of 4 (permalink) Old 12-18-2008, 03:05 PM Thread Starter
Inlay Chart/Update
Just a update the inlay chart
The heart inlay below was made with this updated size, so you can use the 1/4" router bit and the 7/16" brass guide, just to give more room for the bit to spin in the guide...
The offset ring can be used on the PC ( 1 3/16" ) type guides or the ( 1 1/2" ) Oak Park brass guide size.
The 1/4" bit makes it quick to hog out the pocket for the inlay
Just a quick tip how to use the inlay kit, many have a hard time getting this down
The recess is cut with the inlay bushing in place.
The bushing is then removed to cut the profile of the inlay again with the same template pattern.
Making An Inlay Template
http://www.routerworkshop.com/revinlay.html
Just a tip*** keep all the edges round if you can, that's to no sharp corners, then your inlay part will just drop in with almost no sanding of the edges
Note the sharp point ( bottom of the heart ) , this will come about because the router bit will make it a sharp point on the inlay part and must be hand sanded off to get it to fit in the pocket, that's the tricky part...
http://www.leevalley.com/wood/page.a...=1,43000,51208
Name:	inlay chart.jpg
post #2 of 4 (permalink) Old 12-18-2008, 03:18 PM
Bob N's Avatar
First Name: Bob
Good material.... thanks BJ!
Bob N is offline
post #3 of 4 (permalink) Old 12-18-2008, 08:25 PM
scrollwolf's Avatar
First Name: Jack
Thanks bj!
Jack
"If it ain't broke, don't fix it, give it to me!"
scrollwolf is offline
post #4 of 4 (permalink) Old 12-19-2008, 09:59 AM Thread Starter
You're Welcome Bob and Jack
I hope you can use the new size as well
Putting in inlays is the fun part of using the router as I'm sure you know..it's like getting a hair cut and asking for a shave at the same time just adds that nice touch...
Plus it so easy to do
Many ask how to make a sign, it takes a lot of work to plow out the background of a sign and inlays can make it stand out very well ,plus it's almost water tight when your done with the finish .. sometimes it works well to leave the inlays a little proud to get the same look as removing the background...
It only takes a scroll saw/jig saw to make the template for the sign..
plus it only takes one template..
Human Verification
Inlay Options mountain monkey Guide Bushings and Templates 2 08-18-2008 09:42 PM
Finishing Help, inlay, color stain ubernoober Tools and Woodworking 1 02-15-2008 05:56 PM
Bushing set vs. inlay kit ? mharwell01 Guide Bushings and Templates 7 02-02-2008 05:44 AM
My First Inlay - With Tom's Jig Holder... challagan Guide Bushings and Templates 22 11-19-2007 05:11 PM
Inlay Guide Bushing and base plate Doyle Portable Routing 3 06-07-2007 10:25 PM
