Help
Go Back   Router Forums > Routers > Guide Bushings and Templates
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the oldest and largest router and woodworking community on the web! Join in over 29,500 discussions with over 65,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Commercial source for offset rings?
This is a discussion on Commercial source for offset rings? within the Guide Bushings and Templates forums, part of the Routers category; I have to enlarge the opening in my router table to install the Unilift I ...
Old 07-19-2009, 11:35 PM   #1 (permalink)
First Name: Bob
rstermer is on a distinguished road
Default Commercial source for offset rings?
Report Post Report This Post!
I have to enlarge the opening in my router table to install the Unilift I just purchased. The opening needs to be 1/2" smaller than the template supplied by Woodpeckers (which appears to be an exact match for the top plate of the unilift). My largest template guide is 51/64" OD so there is no bit that will get me a 1/2" offset so I can use the supplied template. Is there a commercial source for the offset rings I've seen on this site? If not, I suppose I could also replace the bearing on my pattern bit with a larger diameter bearing. Any ideas as to who might supply them? I don't want to cut out the hole with my jigsaw, I'm looking for something more finished looking. The material is plastic coated mdf.
rstermer
rstermer is offline
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community!
Old 07-20-2009, 02:50 AM   #2 (permalink)
BigJimAK's Avatar
BigJimAK has much to be proud ofBigJimAK has much to be proud ofBigJimAK has much to be proud of
Onr dolution, although not inexpensive, is to replace your router baseplate with one that accepts 1-1/2 OD bushings, such as provided by OP and Veritas. Then a 1/2" bit gets you 1/2".
I have an old RE600 with a 3.75" base plate hole and want to be able to use bushings for portable routing using it, so that's what I'm going to do.
OP offers a 7" ($22) round base for handheld use and an 11" plate ($40) designed for use as a table insert. Both are made with 1/4" phenolic. The 1-1/2"x1-3/8" bushing and nut runs another $24. Their 4-piece bushing set, nut and centering equipment set runs $53.
Veritas makes a 9" round one ($40), made of phenolic that is made for both hand-held and table use. The 1-1/2"x1-3/8" bushing and nut runs another $8. They sell a 6-bushing and ring set (no centering included) for $29.
Not an inexpensive solution, either way, but would help make the "finished look" easier.
BigJimAK is offline
Old 07-20-2009, 02:51 AM   #3 (permalink)
BigJimAK's Avatar
BJ touts the advantages of the 1-1/2 OD setup. Hopefully he will chime in with more information.
BigJimAK is offline
Old 07-20-2009, 03:57 AM   #4 (permalink)
First Name: Bob
One thing I could do is to copy the template I have with a .25" offset and then do the same thing with the smaller copy I made to downsize by another .25", for a total downsize of 1/2". MDF is pretty inexpensive, I think a 2' x 4' sheet of 3/4" is around $9, so that would be a lot less than buying a new base and guides.
rstermer
rstermer is offline
Old 07-20-2009, 04:33 AM   #5 (permalink)
Mike Wingate's Avatar
First Name: mike
Mike Wingate is on a distinguished road
Why not build up the inside edges of the template to suit the template guide and bits that you have? Or make a new template, you only need 4 strips of wood, not a whole sheet of MDF to do so.
Mike Wingate is offline
Old 07-20-2009, 08:36 AM   #6 (permalink)
First Name: Bob
The template corners have a fairly large radius, so doing what you are talking about would be fairly difficult to do whereas what I am talking about would be fairly easy for an inexperienced guy like me to accomplish and get a good result. Thanks for your suggestion.
rstermer
rstermer is offline
Old 07-20-2009, 09:13 AM   #7 (permalink)
Forum Liaison
Mike is a jewel in the rough
To purchase a guide with a removable collar the easy way you can buy the Rousseau installation template kit. This gives you the perfect 1/2" offset you are looking for. You can always use the template for a photo frame...
To view at Woodcraft click here: Buy Template with Router Bushings, ROUSSEAU Deluxe Router Baseplate &
Mike is online now
Sponsored Advertisements. Register to disable this advertisement.
Old 07-20-2009, 09:39 AM   #8 (permalink)
bobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant future
Hi rstermer
Off sets don't need to be round,they can be square,,,this will let you get into the corners without the big radius..if you use a 1/8" bit you can Almost get a square corner,and the best part you can just slip them on and off the guide ...by using just one guide for all the jobs
rstermer
MANY,MANY help files on John's web site
http://legacy.woodshopdemos.com/menu2.htm
Sommerfeld Tools ,Videos
Old 07-20-2009, 12:49 PM   #9 (permalink)
First Name: Bob
rstermer
Mike- As I continue to look at it I believe you are correct. If I select the right diameter cutter, I will get a radius in the corner which matches the radius of the template corners. That should solve my problem pretty easily.
Thanks,
rstermer
rstermer is offline
Old 07-20-2009, 06:51 PM   #10 (permalink)
levon's Avatar
First Name: levon
levon is on a distinguished road
hi Jim, i think this is a square base, i may be wrong?
also, its very easy to make or drill out any plate to accept the 1 1/2 " guide bushings.
levon
levon is offline
Router plate rings.... got lucky Greeneyedeagle Shop Safety 6 04-05-2009 07:30 PM
Tweaking CMT aluminum insert rings? AlanZ Table-mounted Routing 7 01-09-2009 05:14 PM
Funny Commercial on TV ejant Lobby 1 09-27-2004 04:36 PM
