| This is a discussion on Question about mounting a HF guide bushing adapter within the Guide Bushings and Templates forums, part of the Routers category; I have a Bosch 1617. Just bought the HF bushings. I need to make a ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I have a Bosch 1617. Just bought the HF bushings. I need to make a base plate to mount the enclosed adapter to. I can't figure out hole the mounting hole in the base show be made. Any advice? See the second attachment for a profile of this adapter. It seems to me that the mounting holes don't go through anything unless the base plate has a pretty complicated profile itself. Last edited by sofasurfer; 02-06-2010 at 06:54 PM. | ||
| | #2 (permalink) | |||
| Forum Contributor ![]() |
Hi Try it this way, see below ===== Quote:
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | |||
| | #3 (permalink) | ||
I see you placed the screws around the outside perimeter. They can go in the mounting holes through the brass since those holes are recessed. But the way you are showing it the base plate will not sit on the wood because the adapter is mounted to its surface instead of recessed. The way you show it would work but it would need another base plate on the original base plate to make the adapter flush , thus doubleing the thickness of the base plate. See what I'm saying. You could make a thicker base plate and recess the adapter into it but that would make the outer lip irrelavant. I'm trying to figure out what the heck they had in mind when they designed the adapter. I'm thinking the adapter would be recessed into the top side of the base plate and a flat ring would be recessed into the bottom side of the base plate, thus sandwiching the base plate in between. Sorry if I'm making to much out of this but it doesn't make sense. BTW, really nice (and quick) sketch. Mine took a half hour. | ||
| | #4 (permalink) | ||
Hi If the black base plate is in place it should be flat with the adapter plate.. =========
| | #5 (permalink) | ||
This adapter does not fit the Bosch 1617 and I don't see how it could fit anything. If I don't figure it out I will call HF Monday and ask them what it is meant to fit and how it is used. Otherwise I will just have to get the adapter RA1100 from Bosch. | ||
| | #6 (permalink) | ||
I will ring up levon, I think he has one on his Bosch and I'm sure he will post a picture of it , if that would help.. ![]() =======
| | #7 (permalink) | ||
Thats mighty nice of you. That sure would help. I just compared the 2 sets that HF sells. Mine has... * Fits any router that accepts standard 1-3/16” OD threaded guide bushing * Machined solid brass construction * Includes 7 template guides: 1/4” ID x 5/16” OD; 9/32” ID x 3/8” OD; 11/32” ID x 7/16” OD; 13/32” ID x 1/2” OD; 17/32” ID x 5/8” OD; 21/32” ID x 3/4” OD and 5/8” ID x 51/64” OD Plus 2 lock nuts and adapter * 1.25 mm threads The other one they sell has... This set is ideal for any router that has a base plate opening of 1-3/8" diameter. * Includes two locking nuts and one each of 5/16", 3/8", 7/16", 1/2", 5/8", 3/4" and 1" diameter templates I will get back $7 is I exchange it. But it will cost $6 to drive over there. Hmmm. But if Levon has an answer I will sure appreciate it. | ||
| | #8 (permalink) | |||
Hi I did send him a PM, no one home ,,but it looks like he is using a clear plastic plate to hold the brass guides in place..But I will say you can made your own plastic base plate very easy in your shop,,,it's about 20 min.job.. or less ![]() http://www.routerforums.com/attachme...e-100_0802.jpg Router accessories 2 ========= Quote:
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. Last edited by bobj3; 02-06-2010 at 08:24 PM. | |||
| | #9 (permalink) | ||
Well, if I make my own base I don't even need an adapter. It just seems to me that the one in the kit should have a purpose. If anyone has a suggestion I will appreciate it. And a understanding of the parts in this kit should be created anyway. But I'm not going to loose any sleep over it. Thanks. | ||
| | #10 (permalink) | |||
Hi It's a universal adapter plate not all routers can use it, Bosch must be one of them that can't use it.. that must why I'm not a big fan of the big frame Bosch router,,,here's one below that can use it see below..that also maybe why I push the Milescraft base plate..it will fit just all routers and then some.. ![]() ======= Quote:
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. Last edited by bobj3; 02-07-2010 at 08:56 AM. | |||
| Guide Bushing Adapter | scrollwolf | Guide Bushings and Templates | 4 | 09-17-2009 08:29 PM |
| Guide bushing identification | Mike | Guide Bushings and Templates | 27 | 06-19-2009 03:52 PM |
| rockler guide bushing size question | blurry | Router Bits - Types and Usage | 5 | 01-30-2009 12:20 PM |
| [FAQ] How to Post a Question | Mark | Forum Help & FAQ | 0 | 01-11-2009 09:26 PM |
| Router template inlay | V Garry | Introductions | 7 | 12-27-2008 06:49 PM |
