| This is a discussion on A routing tutorial for beginners within the Guide Bushings and Templates forums, part of the Routers category; The first shot shows the finished project, a coin tray for the dressing table, I ... |
| | #1 (permalink) | ||
| Forum Contributor ![]() Join Date: Jan 2007 Country: Australia First Name: Harry Posts: 9,637 ![]() ![]() ![]() |
The first shot shows the finished project, a coin tray for the dressing table, I could have made it on the lathe in perhaps half an hour, or even with the router in a much shorter time than this one took, however, the whole idea of this tutorial is to show beginners, who are no doubt only familiar with table routing, that there are other, more exciting ways in which the router can be used, I've generally used metric measurements because of the cutters and template guides that I have, however, this coin tray can be any size or height that you want, based on what cutters and guides you have. The piece of American Oak that I used just happened to measure 8.5" x 7" x 1 3/8" which added an extra stage to reduce it's height after routing both inside and outside. I would suggest that a 1" thick piece would be better, also a thinner template, about 3/8", this would mean that a collet extension wouldn't be needed. If a dish cutter isn't available, just leave the inside corner square to be continued
__________________ Harry Nothing but heaven itself is better than a friend who is really a friend. - Plautus | ||
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community! |
| | #2 (permalink) | ||
When sorting the photos, I realised that I had failed to take shots of some operations, the most important being how I routed the inside of the tray, so I did a mock set-up to show this with three shots at the end. If anyone has questions, don't hesitate to ask, the chances are that other members have the same questions but are too shy to ask, or feel that the question is foolish, no such thing, if you were in a classroom I'm sure you would raise your hand! I've just noticed that shots 4 and 5 are transposed
__________________ Harry Nothing but heaven itself is better than a friend who is really a friend. - Plautus Last edited by harrysin; 04-14-2010 at 08:58 AM. | ||
| | #4 (permalink) | |||
| Forum Contributor ![]() |
Hi Harry Nice job,,, The only thing I can say on the down side is that 40mm guide thing again, most don't have one in the states and that looks like a real key thing,must have item in your snapshots..to make one like yours..that may be a real turn off for the beginners.. ![]() I know you hate the brass guides but many in the states have the brass guides ( 1 3/16 " PC type ) 1" ID max. you can get the bits to fit but the collet nut will not fit into the guide hole..so to say it will not plunge to deep,1/2" max if that..with the guide in place, many ways to get around that but not for the beginners.. Maybe you should show how to do it with a diff.type of bit like a strait or a core bit. You know me I do it all with just one template and use the BRASS guides and off set rings for the off sets.. http://www.mlcswoodworking.com/shops...s/bt_core.html ====== Quote:
__________________ "It's fine to disagree with other members as long as you respect their opinions" MANY,MANY help files on John's web site http://legacy.woodshopdemos.com/menu2.htm Sommerfeld Tools ,Videos http://www.youtube.com/channel/UCT-n...RWaEpMA/videos Last edited by bobj3; 04-14-2010 at 10:32 AM. | |||
| | #5 (permalink) | ||
| Registered User ![]() |
Sounds like a good point BJ. How about you show how to make the same thing the American way. Although I don't have a 40mm guide, I learnt a lot from your tutorial Harry. Keep them coming, I may just be able to make cool things with the router one day. Hope you're not freezing with the record low temperatures you're having at the moment. | ||
| | #6 (permalink) | ||
Hi Harry, Being a beginner I like these kind of tutorials. They show me methods I haven't used before and are detailed enough that I don't get frustraited or make mistakes. What size bushing did you use to cut the inside of the coin tray(Page #11a)? David | ||
| | #7 (permalink) | ||
| Official Greeter ![]() |
Thanks Harry, Even I can understand that.....LOL James | ||
Sponsored Advertisements. Register to disable this advertisement.
| | #8 (permalink) | ||
Gosh Harry. The timing is impecable. I can not help but think that your tutorial was inspired by my question in the "How to make a template" thread. Anyway, its a very good tutorial. It answers a lot of questions. Thanks. I will study it tomorrow after I get some sleep. | ||
| | #9 (permalink) | |||
__________________ Harry Nothing but heaven itself is better than a friend who is really a friend. - Plautus | |||
| | #10 (permalink) | |||
Do also read my answer to Bj's post
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/guide-bushings-templates/21306-routing-tutorial-beginners.html | ||||
| Posted By | For | Type | Date | |
| Joining 2 different type of wood - Woodwork Forums | This thread | Refback | 12-23-2010 01:02 PM | |
| A routing tutorial for beginners | This thread | Refback | 04-28-2010 03:09 PM | |
| Forum Suggestion Thread | Mark | RouterForums.com News & Feedback | 116 | 05-02-2013 07:28 PM |
| New to Routing and already lost!!! | sarahrodgers | Introductions | 10 | 12-31-2012 11:30 PM |
| CNC routing as first routing experience | ianthehenry | CNC Routing | 23 | 04-25-2012 04:24 AM |
| Routing Template | Verlin Garrett | Jigs and Fixtures | 13 | 10-09-2011 09:09 PM |
| Router table or Plunge routing | template tom | Guide Bushings and Templates | 15 | 04-14-2009 02:45 AM |
