Woodhaven router sleds - Router Forums
post #1 of 5 (permalink) Old 05-17-2011, 08:36 AM Thread Starter
Default Woodhaven router sleds
Hi, I'm new to this forum and would like some information on the Woodhaven router sled. I made an end grain cutting board and want to made more. I had to spend an excessive amount of time sanding my first one. I would use the sled to level the surface of the cutting board. The board I made was approx 11" by 15". If anyone is using one of woodhaven sled I would info on quality of sled and how easy it is to set up and use.
Thanks in advance,
Tom
Tom in NC is offline
post #2 of 5 (permalink) Old 05-17-2011, 09:16 AM
Thanks in advance,
Tom
Hi Tom - Welcome to the forum
I just got the small one a few weeks ago and am pretty impressed with it so far. I've just used it a couple of times to see how it worked by planing down a couple of old drawer fronts. You do need to make a couple of 'L' shaped supports to set the rails on and then support your workpiece somehow. The workpiece needs to be supported such that the surface being planed is within about a 3/8" window. As I said, I have just started using it so haven't worked out all the nuances yet but it is well made and promises to be a very versatile system. Fairly cheap also if comparing to a planner.
If cutting boards is to be a sole use for it though, you might be able to make a home built version with a simple frame and gantry type carriage for the router. I believe another member built something like that awhile back. If I can find it, I'll post a link to his creation.
EDIT - Here's the link
http://www.routerforums.com/jigs-fix...tml#post207073
John Schaben
jschaben is offline
post #3 of 5 (permalink) Old 05-17-2011, 10:08 AM Thread Starter
John, thanks for the reply. I believe I will go ahead and order one. Cutting boards is my current concern. I have needed something to flatten boards wider than my 6"jointer can do an I believe this will also do that also.
Tom
post #4 of 5 (permalink) Old 05-17-2011, 02:21 PM
Tom
Hi Tom - here's a couple of pics of mine set up with an old drawer front I still had
John Schaben
jschaben is offline
post #5 of 5 (permalink) Old 05-23-2011, 10:39 AM Thread Starter
I ordered the Wodheaven sled and it's to be delivered today. I wll let you how it works on mend grain cutting boards.
Tom
Human Verification
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 06:40 PM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 11:01 PM
Grizzly G1035 Shaper vs Router Table GAVolunteer Table-mounted Routing 11 06-30-2010 07:35 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 03:45 AM
