making a base plate help please ? - Router Forums
post #1 of 8 (permalink) Old 11-24-2011, 01:25 PM Thread Starter
First Name: Keith
OK i'm not generaly thick but I am trying to get my head round one thing, making the hole and lip for the pc type bush's. I am using acrylic, I have 5mm thick and 2mm thick and the way I was going to do it was make the base is this, I have used the Erbauer standard base and coppied that, cutting it out using my rotozip and the circular cutting tool, the way I thought you found the center point was to mount the new base plate on the router and then by using say a V bit gently plunge the router to just pierce the acrylic, I thought that by doing that would make the hole central ? am I right ?
then using the center hole I have just made (only small hole by the way say 3mm?)
then using a forstner bit to sink a rebate to fit the bushing adapter plate. finally i could use any number of bigger router bits to cut the through hole with the new base plate fitted?
does this make any sense ? because other than this way I cant think of a way of making sure the base plate hole and fitting for the adapter plate would be central
thanks chaps
Tazkb is offline
post #2 of 8 (permalink) Old 11-24-2011, 05:58 PM
thanks chaps
Hi Keith. That's the way I do it, except I use a 1/8" (close enough to 3mm) spiral bit and make a through hole. Basically the same process you just described though,.
then take the base plate off and use that hole to drill the relief and the through hole. Just drill the relief before you drill the through hole otherwise you loose your reference.
John Schaben
jschaben is offline
post #3 of 8 (permalink) Old 11-25-2011, 07:58 AM Thread Starter
First Name: Keith
thanks John,
and how do I cut the lip ? people on here have mentioned using a forstner bit ? but i would need one 62mm in diameter ? the kit i bought was the silverline bushing kit, the brass adapter size is 68mm od with a 62mm lip and 30mm center hole ? and I cant find a 62 mm forstner bit ?
Tazkb is offline
post #4 of 8 (permalink) Old 11-25-2011, 08:48 AM
BrianS's Avatar
First Name: Brian
Hi Keith. You can also use a hole saw with good results.
Brian
They say marriages are made in heaven.... but so is thunder and lightning.
Clint Eastwood.
BrianS is offline
post #5 of 8 (permalink) Old 11-25-2011, 09:02 AM Thread Starter
First Name: Keith
sorry guys it's just occured to me that making a new base plate I don't need to make a lip to fit the 62mm adapter plate dohhhhh ! I just need to make a lip to fit the the guide bush's which is just over 30mm ? what a thickie sorry guys i'm not firing on all cylinders today
Tazkb is offline
post #6 of 8 (permalink) Old 11-25-2011, 10:09 AM
Hi
Who said it needs to be round. a sq. one works so much better
Oak Park Enterprises Ltd.: Catalogue
http://us.oak-park.com/catalogue.htm...&product=BP093
http://us.oak-park.com/catalogue.html?list=BP-7BP-
http://us.oak-park.com/catalogue.htm...roduct=MBK0990
By the way hole saws suck they are made to cut out a hole not a flat bottom hole. that's needed for the lip of a guide..
http://www.leevalley.com/en/wood/pag...00,51208,41778
forstner bits Cheaper than hole saws the norm
http://www.ptreeusa.com/forstner_bit_sets.htm
" Benjamin Forstner patented his forstner bit on Sept. 22, 1874. The successful invention of the forstner bit was to make him a rich man. Without the lead screw (which Forstner calls the "gimlet-point") and cutting lips of more conventional wood boring bits it would prove especially useful to gunsmiths like himself and other high-end woodworkers. The forstner bit was unsurpassed in drilling an exceedingly smooth bore hole, with a flat bottom."
post #7 of 8 (permalink) Old 11-25-2011, 11:11 AM
I use hole saws for this. A lip the width of your hole saws teeth is plenty of support for the guide bushings and since the hole saws teeth are all at the same level it only requires you to monitor the depth of cut. I use mostly Lenox hole saws which have nicely hooked, uniform teeth. Note also the nice hole design on the sides which makes it super easy to pry out the plugs with a screwdriver.
post #8 of 8 (permalink) Old 11-25-2011, 06:14 PM Thread Starter
First Name: Keith
square bases seem quite popular and as such while I have a chunk of spare acrylic around I fully intend making a square base, as well as a standard shaped one. I have ordered a 35mm forstner bit to cut the lip and allready have a 30mm one to cut the hole. I have no problem with hole saws but the quality varies greatly, cheap ones wobble a lot and you end up with a hole either bigger or slightly out of shape. only the more expensive ones i would trust enough on such a delicate object
thanks guys
Tazkb is offline
Human Verification
Base Plate for Craftsman Router Steve1946 Craftsman 12 12-04-2014 07:22 PM
Making a Plate TWBryan Table-mounted Routing 2 08-08-2011 11:39 AM
The Marvel 3 in 1 tool from MLCS: base plate and table mount advice please loninappleton Table-mounted Routing 4 07-10-2010 09:32 PM
Polycrilic Plate Thickness cbsjoez1935 Starting Off 5 09-28-2009 07:56 PM
Base Plate Help CanuckGal Portable Routing 47 05-16-2009 05:10 PM
