Help
Go Back   Router Forums > Routers > Guide Bushings and Templates
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the oldest and largest router and woodworking community on the web! Join in over 29,500 discussions with over 65,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Centering Base Plates
This is a discussion on Centering Base Plates within the Guide Bushings and Templates forums, part of the Routers category; I know the basics about centering the plates on my Porter Cable router bases but ...
Old 12-08-2011, 11:36 AM   #1 (permalink)
First Name: Brian
Uncle Nick is on a distinguished road
Default Centering Base Plates
Report Post Report This Post!
I know the basics about centering the plates on my Porter Cable router bases but never get them exactly centered. I was hoping to get some feedback on the process.
The Process
The PC bases are mounted to the base with 3 countersunk machine screws. After removing the screws and the plate, I counterbored the exsisting countersinks on the plate with a 3/8" Forstner bit and enlarged the through hole a little bit. I replaced the original countersunk screws with the appropriate size pan head screw. The counterbore is deep enough to allow the new screws to sit below flush. The modified and enlarged holes should permit me to align the base (with a bushing installed) to a centering pin mounted in the collet. I use the centering pin that came with the bushing kit (Rockler #59031). After alinging the base with the pin I tighten the screws on the plate.
After all of that, I run some tests and get off-center results. There have been times after chucking a bit in the collet I visually check and can see that the bit is not centered.
Any suggestions?
Uncle Nick is offline
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community!
Old 12-08-2011, 11:56 AM   #2 (permalink)
Cassandra's Avatar
First Name: Cassandra
Cassandra is on a distinguished road
Hi Brian:
Welcome to the Router Forums!
The technique I use:
1. Fasten the base-plate to the base, leaving the screws loose. (The ones in the base-plate!)
2. Chuck up a 1/4" drill blank in the collet.
3. Insert and tighten a 1/4" ID bushing in the base-plate. Make sure the router is locked down (on the 1617EVS I have, I close the locking clamp.)
4. With the drill blank passing through the bushing, I tighten the base-plate screws.
One can use a 1/2" drill blank and 1/2" ID bushing, or the 8mm variety -- the technique applies.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
Old 12-08-2011, 01:21 PM   #3 (permalink)
Forum Liaison
Mike has a spectacular aura about
Brian, you might also consider buying a centering cone. The one shown is designed for the Bosch 1617 but will work with any router.
Old 12-08-2011, 02:26 PM   #4 (permalink)
bobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant future
Hi
Buy any MilesCraft kits and you get one FREE..
Plus a free base plate to boot that will fit any router and you can use your PC type guides with it right off the bat and the screws come with it for free ,to mount it to your router .
http://www.amazon.com/Milescraft-120...378534&sr=1-17
MANY,MANY help files on John's web site
http://legacy.woodshopdemos.com/menu2.htm
Sommerfeld Tools ,Videos
Old 12-08-2011, 09:58 PM   #5 (permalink)
Forum Liaison
You can also get the Milescraft kit BJ mentioned at Lowes for $19.97.
Old 12-03-2012, 12:34 PM   #6 (permalink)
First Name: Benedikt
achoox4 is on a distinguished road
At Lowe's just now, I noticed it now comes with brass-nosed bushings. (Meanwhile, the Amazon price is down to $20 as well, but I suppose their stock might be older and all-plastic like their picture still shows.)
Is there any reason (for a beginner) to start with an all-brass set for $40 (plus base plate or Bosch holder cost) instead of the Milescraft plastic/brass setup? Is this one of those things where as long as I don't wear out the less-tough setup, I'm not using it enough to warrant spending 2x+?
achoox4 is offline
Base plates that recieve guide bushings TanOak Table-mounted Routing 10 10-15-2011 09:55 AM
Vertical Flush Trimming Base Plates taxque Portable Routing 10 06-27-2010 02:31 PM
Question about the Oak Park base plates tpyke Table-mounted Routing 3 12-21-2007 06:02 PM
sub base and base plates 46_trap Jigs and Fixtures 0 05-23-2005 02:39 PM
Centering Base Plate -Sam- General Routing 15 01-04-2005 10:15 AM
