Go Back   Router Forums > Routers > Guide Bushings and Templates
Rate This Thread - Carving with the router.
Thread Closed
Thread Tools Display Modes
Old 02-07-2007, 05:26 AM   #1
template tom
Forum King
Default Carving with the router
Hi all
I would be interested if anyone has done any carving with the router. I saw a design and I was wondering if it could be cut with the router.
Has anyone any idea. I will give it a go.
Tom
template tom is offline   Top -
Old 02-07-2007, 06:37 AM   #2
AxlMyk
Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
Well, you could part with $2000 and buy the Craftsman CNC machine.. That way we would have a test person to report on it for us..
Other than that, perhaps something with a flex shaft.. That could be a tough one Tom..
AxlMyk is offline   Top -
Old 02-07-2007, 06:54 AM   #3
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
It looks a lot like a design that could be made with the Milescraft Spirocrafter.
http://www.milescraft.com
I got one for christmas and haven't been able to use it yet. Uses a template guides and small carving and inlay bits.
challagan is offline   Top -
Old 02-07-2007, 07:41 AM   #4
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Mike, as you know Sears doesn't build any of the tools they sell. The CompuCarve is made by CarveWright. To visit their site just add: .com to watch the demo and see items they have produced.
Mike is offline   Top -
Old 02-07-2007, 08:14 AM   #5
AxlMyk
Forum King
AxlMyk's Avatar
Yes, I've seen the site..
Old 02-07-2007, 09:09 AM   #6
kp91
Forum King
kp91's Avatar
Tom,
I saw a guy a few years back at a woodworking show in the States who carved entry doors with a router almost exclusively. He used a bit that looked more like a 1/4 inch round nose carbide burr to hog out most of his material, then finish up with a bowl bottom bit or small spiral bit. It was amazing how fast he could do his carvings. Unfortunately, I can't remember his name.......
He did it all free hand, no guides, just a big clear sub plate.
1 John 1:9
kp91 is offline   Top -
Old 02-08-2007, 03:45 AM   #7
template tom
Forum King
Thanks to all who responded to the posting.
What I was trying to find out can this be achieved with the router in the plunge mode with the aid of template guides, without the need to go and purchase any expensive equipment.
Well the answer is yes today I went to my workshop to prove it could be done and I have posted the results. This opens up another method of using the guides I had never considered before. I will leave you to put on your thinking caps and see if you can come up with the answer before I submit the solution to the problem.
When I went to my workshop with the necessary drawings required to make the template I was unsure of the final results that I could achieve and I am very happy with the technique I used though I would change the design slightly based on an elliptical shape. So I will get back to the drawing board and make the necessary changes to improve the design.
Anyway I would be interested in your method if you were interested in the challenge to Carve with the router without the expense of purchasing the jigs that were considered for purchase.
My expenses were a piece of MDF 400 x 300 x 9mm and the material fitted into my original jig holder See "introduction to the use of template Guides"
Tom
Old 02-08-2007, 09:35 AM   #8
AxlMyk
Forum King
AxlMyk's Avatar
I knew it.. That was a trick question all along..
I can see how an inside template would be used, and I'm thinking that one double-back taped to the wood, then rout around the outside of it..
Old 02-08-2007, 07:38 PM   #9
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
Hi Tom,
Yes, I thought it was a "Setup" too... I just KNEW that you were going to show us how you did it...
But, no, you just show us the finished project...
I'll bet it wasn't done with a 40mm guide!
Making the original for routing... how did you make it?
I wasn't sure how all of those lines were supposed to be handled...
OK, Tom, you have more pictures for us... yes?
Thank you for coming through!
Joe Lyddon is offline   Top -
Old 02-08-2007, 10:27 PM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
See the item below
Bj
Hi Tom and Harry
All I'm saying is it's not the same , If I ask you to carve a pine tree and you carved a elm tree,,, hummmmm ,it's not the same both are trees but not the same.
If I gave you a pattern and I ask you to copy it,,,,and you came back with one that was almost the same but not like the one I gave you.
But you did a great job doing your tree.
Maybe we should ask Charles M. ( forum member ) to take the pattern you posted and put it in his new CarveWright machine and make one just to show how it should look when you use a real carve router to make it.
If you get some time go to the CarveWright web site and look at some of the items this machine as made, all I can say is WOW, it was done with a router bit and a machine that you and I can now buy without paying $15,000.oo or more for a CNC router setup.
It's a new age of routers and computers and it's only get better for the small wood shop.
If you want to play you must step up to the pump so to speak just like the computers.
http://www.carvewright.com/forum/vie...9f1f33506759b8
Like the ones below
Bj
carving-router-umc.jpg  carving-router-carve-box.jpg  carving-router-3-kids.jpg  carving-router-doors.jpg
bobj3 is offline   Top -
Thread Closed
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 08:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
New Router my way reible General Routing 14 06-10-2006 10:19 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
