Go Back   Router Forums > Routers > Guide Bushings and Templates
Guide Bushings and Templates This is where to learn about the different types of guide bushings and how to use them, how to create templates, how to build a frame to hold your work piece, and how to combine them all to create a project.
Thread Tools Display Modes
Old 02-19-2007, 04:25 PM   #1
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Default Tom.... Question On Template Holder..
I received some templates for Christmas.... patterns I guess.. not sure what you call them. The outside dimensions are all the same size. These are made of plastic or resin. I also got a inlay guide and bits to do the inlay carving. Got a diamond shape, oval etc. I want to use these on box lids.
Just thinking, if your pattern holder could be made adjustable to different sized patterns etc. Have you ever made one that was adjustable? Am I making sense here to you?
challagan is offline   Top - Reply with Quote
Old 02-19-2007, 05:05 PM   #2
template tom
Forum King
You can make a simple Jig Holder to hold most size Templates. If the templates are the ones I am thinking about there should have been a means of positioning them to achieve the desired results. What about posting a pic or two.
I have never really made any of my Jig Holders adjustable. If the size changes and it will not fit into one of my original holders I make a new one. The next project may fit into the new one so there is no waste.
Tom
Old 02-19-2007, 06:31 PM   #3
challagan
Supreme Forum King
challagan's Avatar
Thanks Tom, these are the templates I am referring to. At a second look, the 3 I have are all different sizes.
http://www.hartvilletool.com/product/12315
I guess more importantly you have to build the holder to hold the stock being inlaid. I have to give this more thought. I would like to use your jig holder idea to do my inlay and carving work. See this is the type of work that interests me. I am not really much of a pattern routing guy. I primarily do boxes and i want to do more of the carving and inlay work on them.
These templates are 1/4 inch thick or 6mm. I guess that is where I get confused on all this is that the template needs to sit up level with the holder so it's travel isn't impeded by the sides of the jig holder. How tall is your jig holder, is it 45mm tall?
So I would build the holder to the size of the material being routed. Say 1/4 material 8 x 10 inches. The patters are 1/4 inch this so I need a piece of material 1/4 thick that is 8 x 10 and a cutout in the center to hold the template, right? That is 1/2 total of material at this point. So how tall would you make the template holder? I hope I am making sense here to you. I don't really understand the whole shelf thing?
One of the things I want to achieve is to do a box ( knife box for my son) with an oval inlay and inside the oval inlay I want to do some carving of initials. Same thing for a jewelery box for my daughter. These are to be Christmas 07 projects so I have time
Perhaps I will have to make a template to carve the letters I want to use. I need to use the letters EJH and HJH so I will basically need to make three letter templates. I am not sure what exactly the font I want to use yet but I want something fairly fancy looking.
Ok, enough ramblings
Old 02-19-2007, 10:41 PM   #4
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Corey, this isn't as tough as it seems. You will start out by deciding on the size of your box lid. Lets say 8" x 10"? For doing inlay work you will most likely want a lid that is 1/2" thick at first. The main consideration is that the 8x10 fits into the frame with a way to secure it like the cams. If you use 1" hardwood dowel to make your cams allow an inch all the way around your project or in this case you frame will need to be at least 10x12", 11x13" would be better to allow a bit more room for adjustments. How deep does this need to be? We know the material you will be routing is 1/2". We have to allow clearance for the double sided tape that will be underneath it.(call it 1/32") This means your frame must be 17/32" in height to work. You may want to inlay on 3/4" thick material at a different time, so the frame would need to be (3/4" + 1/32" = 25/32") in height. Since the template will be supported by the frame it does not have to sit on the material. Why not make it simple and use a 1" height? Having your wood 1/2" below the template is not a problem since your router will plunge more than this. Does this help you picture the frame and how to design one for your project size?
Mike is online now   Top - Reply with Quote
Old 02-19-2007, 11:16 PM   #5
template tom
Forum King
[quote=challagan]Thanks Tom, these are the templates I am referring to. At a second look, the 3 I have are all different sizes.
That gives me a better chance to answer your questions
Yes the Jig holder is made to hold the jig where the material is secured to. this same jig holder supports the template to be used. You mention the templates are different sizes. In that case I would make a template for each template you have. That is the template would sink into the middle of the template in the same way we sink the router into the router table. Obviously you are going to rout more than one. This new template with the insert is made to fit neatly into the jig holder. The original template will be set proud of the new template by 1/32" at least.
Note: The size of the new template will be determined by the size of the largest piece of material you are to use
The height of the Jig holder is not critical (I use min 40mm) as you simply add packing material under your jig to raise it to the required height. Yes the template need to clear the Jig Holder to prevent the router base from touching the sides of the jig holder.
[color=Navy]I think this has been answered above[/COLOR
Not too clear on this point Corey
Looks as if you will be producing items of various sizes as I suggested above make your Jig Holder to suit the largest item. I have a variety of Jig Holders to take a variety of projects. Not one jig holder will suit all we wish to do.
Corey I have not got into letter routing I know there are lettering kits on the market but nothing fancy.
Hope this helps
Tom
Old 02-19-2007, 11:23 PM   #6
challagan
Supreme Forum King
challagan's Avatar
Mike, yes thank you, it does help some. Sorry don't mean to make this so difficult I guess for box work I was thinking it would be just as simple to make the holder the size of the work piece. So if my lid is 8 x 10 then why not make the holders inside dim 8 x 10. Then you could just center up the pattern on the top of the work piece. For my box work my panel would most likely be a 1/4 thick and inlaying 1/8 material into it. Center the template up on the material and trim it out with mdf or what ever to the necessary dimensions so it is supported on all sides and can't move. I guess that makes more sense to me than messing with all the cams and shelf supports etc.
Probably making more work out of it but I guess that's how I envision it anyway.
Old 02-19-2007, 11:32 PM   #7
challagan
Supreme Forum King
challagan's Avatar
Tom, thank you for that. We were both typing posts at the same time I think. My friend it is starting to sink in a bit between you and Mike!
You answered a couple of my questions here and the new template for the template is what I was thinking originally. I just wish I could finish the kitchen and get to work on some of these things.
But I have some ply to make a base to attach the jig holders to and I can start messing with the holders anyway. On the letters.... I don't like the "sign lettering templates"... they look to much like road sign lettering. Maybe I can be a pioneer here. If I can get the templates made of the scroll saw to get the letters to look right the way I want them to... I think the holder is the best way to do the actual routing.
Anyway thank you Tom for your help and time.
Old 02-20-2007, 12:02 AM   #8
Senior Moderator
Supreme Forum King
Corey, here is another thought. You might simply rout out an oval shape on your lid, then glue your scroll sawn letters in place. You can then add a tinted epoxy filler to the void areas. This would create sort of a medallion appearance. If you want this to be true inlay work the letters will have to be pretty large, remember you will be working with a 1/8" down spiral bit.
Old 02-20-2007, 12:11 AM   #9
challagan
Supreme Forum King
challagan's Avatar
Mike, the scroll saw idea I have thought about but I was actually thinking of carving those in the oval if possible. If I was real good I could inlay the oval and then do a scroll saw inlay with the letters, but my eyes won't let me do all the fancy scroll work like I used to do. It's hell getting old! LOL.
Old 02-20-2007, 12:30 AM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hey old guy with bad eyes
Here's a tip I got from whitewoft710, get the saw up to your chest and tip it forward that's to say put a block of wood on the tail end of the scroll saw so it's at about 20deg.or so ,the stock will slide off and all the saw dust will also.
I used a 4 x 6 block of pine, this works great for old guys like me that have bad eyes and a bad back on top of that.
Now I can see and sit at the saw for 2 or 3 hours at a time without getting off the chair and saying that's it I done for a week or so.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Half Blind Router Template Question stevek433 Introductions 4 03-01-2008 12:17 PM
Template Routing FlyFAmerica Portable Routing 8 01-22-2007 09:57 PM
Hitachi M12V template guides? vwmowery General Routing 6 09-01-2006 12:51 AM
Template, how to make? smacmullin Jigs and Fixtures 2 11-08-2005 05:52 PM
Router template question Sebisant General Routing 1 10-05-2005 07:10 AM
