| Guide Bushings and Templates This is where to learn about the different types of guide bushings and how to use them, how to create templates, how to build a frame to hold your work piece, and how to combine them all to create a project. |
| | #11 | |
| Registered User Forum King | Quote:
I hope I understand your question. Correct me if I am wrong You wish to know what size of cut-out required in a template. This will be determined by the template guide and cutter combination to be used and of course the size of the project cut-out. If the size of the material cut out say is 8" x 4" and we are using a 3/4" Guide and a 1/4" cutter. The size of the template cut-out required would be 8-1/2" x 4-1/2" I hope this answers your question Tom | |
| | #12 | |
| Retired Moderator Supreme Forum King | Quote:
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ | |
| | #13 |
| Registered User Supreme Forum King Join Date: Nov 2006 Location: Fort Worth,Texas USA First Name: George Posts: 1,588 ![]() | If I am reading all this correctly the formula to figure the offset would be: 1/2 x (bushing OD - bit size) = offset Then take the offset, double it and add this to the dimensions of the desired opening. Is this correct? ![]()
__________________ George For those who haven't already done so... PLEASE! PLEASE! Fill in your first name and location in your profile. |
| | #14 |
| Forum Contributer Supreme Forum King | Tom, whilst I wouldn't attempt to argue with you're answer, which is of course correct, if during lessons with you I had only received answers and not been taught how to do the calculations I would be in a very sorry state. Isn't it simple to just state that guide radius plus cutter radius equals offset? In the case in question for a finished project measuring 8" x 4" using a 0.75" guide and a 0.25" cutter: 0.375" + 0.125" = 0.5" ie: cut-out is 0.5" bigger than the project or as Tom has stated 8.5" x 4.5" |
| | #15 | |
I am sure you did mean minus instead of plus Tom | |
| | #16 | |
Correct Tom | |
| | #17 |
| Forum Contributer Supreme Forum King | Hi Tom, no, I did not mean minus, but, I must apologise for incorrect terminology, the results from my formula give you the increase in the size of the cut-out compared to the finished size of the project, not the offset which would of course require the two figures to have a minus sign between them, I do hope that you will forgive this transgression, I shall attempt to do better in the future you're former pupil Harry |
| | #18 |
| Registered User Supreme Forum King Join Date: Nov 2006 Location: Fort Worth,Texas USA First Name: George Posts: 1,588 ![]() | It looks like we are all getting the same place by going down different roads. The correct answer is what matters irregardless of the method. I am going to get this template thing down even if it hairlips the governor. It is good to have more than one way to accomplish a goal. I have found that some people will not understand one method or terminology, but when explained another way the light bulb will suddenly come on. By having more methods or different terminologies you have the potential of reaching more people and that is what this forum is all about. So keep it up Guys. Different is GOOD!
| Guide Bushings | rberry | Portable Routing | 14 | 06-15-2008 09:42 AM |
| Working with bushings for in-lays | schlott | Starting Off | 5 | 04-14-2008 10:37 AM |
| bushings vs bearings | peacefrog | Guide Bushings and Templates | 4 | 11-08-2007 10:39 AM |
| question about router plate | mwm500 | General Routing | 5 | 09-20-2006 06:58 PM |
| thomasjohnusa | thomasjohnusa | Introductions | 3 | 05-20-2006 01:53 AM |
