| | #1 |
| Registered User New Member | Is there a way to be able to easily figure out where a cut will be by using bushings? EXAMPLE, If you were using a 3/4 bushing and a 1/4 bit,would it be around 7/8 from workpiece to end of cut. Thanks |
| | #2 | |
| Retired Moderator Supreme Forum King | Quote:
One of the template guys will let's us know if this is right or if I am full of it! Corey | |
| | #3 |
| Forum Contributer Supreme Forum King | Hi George6149 Here's a chart that may help. ![]() Bj ![]()
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html Floating Mortise & Tenon: A strong and Silent Joint |
| | #4 | |
Corey | |
| | #5 |
| Forum Contributer Supreme Forum King | Outside (inside Diam of bushing) = distance Bj ![]()
| | #6 |
| Registered User New Member | Thanks everyone. The chart is great. My question has been answered. |
| | #7 |
| Registered User Supreme Forum King | Thanks for the chart Bj. I have been trying to make a template and keep messing up on the measurements. Maybe I can get it right now.
__________________ George I did not chop down that cherry tree!!! But, since its down, can I have the wood? |
| | #8 |
| Forum Contributer Supreme Forum King | You'er Welcome George This item was made by " Ed " ( forum member name of "reible" ) and he did a great job making it up. Bj ![]()
| | #9 | |
| Registered User Forum King | Quote:
There is no need to measure the inside diameter of the guide. The only concern is will the cutter fit through it ok Tom | |
| | #10 | |
Unable to ascertain what you are trying to say here with this posting. Tom | |
| Guide Bushings | rberry | Portable Routing | 14 | 06-15-2008 08:42 AM |
| Working with bushings for in-lays | schlott | Starting Off | 5 | 04-14-2008 09:37 AM |
| bushings vs bearings | peacefrog | Guide Bushings and Templates | 4 | 11-08-2007 09:39 AM |
| question about router plate | mwm500 | General Routing | 5 | 09-20-2006 05:58 PM |
| thomasjohnusa | thomasjohnusa | Introductions | 3 | 05-20-2006 12:53 AM |
