| | #1 |
| Forum Contributer Supreme Forum King | Here is a photographic explanation of how the lid was made. 1-Removing waste 2-Stock centred into jig 3-Female template in position 4-Initial clean-up using 1/2" cutter 5-After three cuts 6-After final clean-up with 3/4" dish cutter,packing piece on left,plug (male template) on the right 7-Half inch cutter about to rout the outside 8-As above but showing the ski's 9-Outside finished leaving the last 1/8" for the band saw 10-On the band saw 11-Close-up,who can tell me why the routed groove is stepped? 12-After the band saw 13-Ready to trim 14-Lid looks too deep so will plane some off the inside edge in the ski mode will also plane off the box round-over 15-Close-up of depth adjustment showing how deep each cut is 16-Planed lid upside-down back in jig ready to rout cut-out for inlay 17-Routing cut-out 18-The cut-out 19-Inlay glued into cut-out 20-Finished box complete with family jewels I'm sorry, but the pix have become totally jumbled, I shall have a word with Mike to see if they can be sorted. Harry Last edited by harrysin; 03-23-2007 at 08:22 AM. |
| | #2 |
| Forum Contributer Supreme Forum King | Nice Show And Tell Harry Good JobThe only thing I don't see is how you hold the template in place to do the outside of the lid I'm guessing it's push in plug in the hole you hogged out in the center of the lid/box. A 2 step plug type template maybe, GREAT job. ![]() By the way I like the graph paper looking table cloth now if I knew what size that sq. is, it would tell me the size of the box. ![]() Bj ![]()
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 03-23-2007 at 11:37 AM. |
| | #3 |
| Forum Contributer Supreme Forum King | Yes Bob,as mentioned,I planed the lid with the router on the ski's,also you may remember that I put a round-over on the box to cover some tear-out, I also planed this off so that the lid is a nice close fit.The plug,or male template is a tight fit into the box but also has the packing piece below it.Hopefully i shall be able to get the pix into the proper order so that it all makes sense.Cheers, Harry P.S. Bob,in spite of it being 11.00pm here,just for you I have gone into my shed to measure the squares on the ex-tablecloth,now a dust sheet,they are exactly 1" squares.Harry 2nd edit. My wife has just told me that it was a bed sheet, not a tablecloth! Last edited by harrysin; 03-23-2007 at 09:05 AM. |
| | #4 |
| Forum Contributer Supreme Forum King | Thanks Harry ,1" will help me and others I'm sure"bed sheet" =LOL, that's makes it easy ,this is your side and from this mark it's mind , Good Night Harry ![]() Here's a tip I use. ![]() "proper order"= box-lid-lid-1 box-lid-lid-1A box-lid-lid-1B box-lid-lid-1C box-lid-lid-1D and so on ![]() Bj ![]()
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 03-23-2007 at 09:09 AM. |
| | #5 |
| Forum Moderator Supreme Forum King | Great photo turtorial Harry! Sure gives me some ideas to consider.
__________________ Cheers, Bob Pictures from the shop http://s107.photobucket.com/albums/m292/bnoles616/ |
| | #6 |
| Banned Supreme Forum King | Very nice Harry. I like that inlay... did you make it? Did you use an inlay router guide inlay kit to do it? Looks like it went very much like the box but not so deep... and you went skiing this time. Nice job! |
| | #7 |
| Registered User Supreme Forum King | Excellent job Harry. The box came out great. Thank you for the pictorial.
__________________ George If you can't fix it with a hammer, you've got an electrical problem... |
| | #8 |
| Registered User Forum King | Thanks Harry That was a great pictorial explanation. Now I hope others will see there is no need for the bandsaw to shape the outside then use sanding machine to produce the finish. Routing the edge will produce a better surface and also consistant thickness to the sides. (Subject to producing a neat 'Male' template) The male template (PLUG) can be produced with the router once you work out the off-set and it will fit neatly into the base of the box. Excellent job with the inlay on the top of the box. Tom Last edited by template tom; 03-23-2007 at 05:15 PM. Reason: spellcheck |
| | #9 | |
| Banned Supreme Forum King | Quote:
Nice job Harry!! Looks great! Still curious about the nice inlay... | |
| | #10 |
| Forum Contributer Supreme Forum King | Hi Joe,the inlay is purchased as shown in pix 13th from top left,it also shows the template that I made with a hole in the centre for the template guide.The router could easily have been used hand held as it sits on top of the template but as I have mentioned in the past,using the router on ski's gives better control and it gives a feeling that from memory is almost as good as sex! I shall attach a pix of some inlays that I use and are readily available over here also a couple more shots of the box after staining but prior to polishing with Danish oil.Keep watching,Harry |
| I have never routed, but am going to start. | Muftobration | Introductions | 9 | 06-09-2008 01:43 AM |
| Freehand routed signs, for AxlMyk | harrysin | Lobby | 3 | 12-27-2007 06:07 AM |
| Easily Routed Bowls via Woodsmith #170 | Joe Lyddon | Portable Routing | 24 | 12-01-2007 01:45 PM |
| Freehand Routed / Hand Carved Sign | RStorment | Show N' Tell | 5 | 10-06-2006 02:26 AM |
| Template routed art pieces | tsaxby | Introductions | 6 | 02-08-2006 03:05 PM |
