Go Back   Router Forums > Routers > Guide Bushings and Templates
Guide Bushings and Templates This is where to learn about the different types of guide bushings and how to use them, how to create templates, how to build a frame to hold your work piece, and how to combine them all to create a project.
Thread Tools Display Modes
Old 05-13-2007, 12:32 PM   #1
Wood Dog
Jr. Member
Wood Dog's Avatar
Wood Dog is on a distinguished road
Cool "Guide Bushings"
I've never used guide bushings,and need to know how to go about making a templete guide for a router plate opening! I recently bought a "Wood Pecker" router lift,problem is it it the "Bench Dog" size 8 1/4"x11 3/4". Thanks!
Wood Dog is offline   Top - Reply with Quote
Old 05-13-2007, 01:15 PM   #2
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Try this link Wood Dog:
http://www.binkyswoodworking.com/InstalRoutBase.html
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 05-13-2007, 01:38 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Wood Dog
Some times brass guides and templates guides are called the same thing.
The brass guide is the item that will go into the base plate and it will follow the template(s) or pattern.
The key to using the brass guides, is to have a base plate that will take on the brass guides some WoodPecker insert plates will have one in the set and some don't.
But you can order one or rework one you have.
http://www.woodpeck.com/liftshome.html
http://www.woodpeck.com/inserts.html
brass guides below
http://www.harborfreight.com/cpi/cta...emnumber=95160
For the plunge router below ▼
http://www.routerforums.com/guide-bu...te-guides.html
http://www.routerforums.com/email-ro...ing-chart.html
Many tips from Bob and Rick ▼
http://www.routerforums.com/email-ro...ly/index2.html
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-13-2007, 02:40 PM   #4
challagan
Supreme Forum King
challagan's Avatar
Wood Dog, the link I gave you shows you how to make a template that the router sits inside of the template and then you route around the interior. Another way to do it is to make a template that plate fits perfectly on the inside of the template. Just build it around the router plate. Then you double stick the template down to the router top and with this method you would use a pattern bit instead of a plain straight bit to route out the interior to the proper depth. Remove the waste by drilling holes and the corners and jig sawing out. I think using the tape is probably a good idea in either installation method and dont remove the template until you know you got it set and all fits perfect.
