Go Back   Router Forums > Routers > Guide Bushings and Templates
Guide Bushings and Templates This is where to learn about the different types of guide bushings and how to use them, how to create templates, how to build a frame to hold your work piece, and how to combine them all to create a project.
Thread Tools Display Modes
Old 08-04-2007, 05:48 AM   #41
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
I thought I would submit this design which Harry and I had a great deal of discussion with some Years ago and I suppose this could also have been one of the reasons Harry was converted to the use of the guides.
Tom
That really makes me realise how time has passed. If I remember correctly, I told Tom that I knew how to use the router and had been using a couple of them for many years and I think he was impressed, that is until I told him how I had made the pattern, which was by hand- making a male template from Hardboard, pinning it to the wood and going round it with what I later knew as a template guide but one that I thought for years was MY invention! The next time that I saw Tom he had drawings showing me how to make a FEMALE template that would produce a perfectly symmetrical pattern every time. Now, over the last few weeks I have shown how to make simple templates so why don't some of you make an attempt, bearing in mind it really is straight forward and the SINGLE template requires no special tools or skills.
Harry
harrysin is offline   Top - Reply with Quote
Old 08-04-2007, 05:08 PM   #42
gregW
Forum Fanatic
gregW is on a distinguished road
nicely done Harry ...
you can almost hear hundreds of light bulbs turning on all over the world
Greg
gregW is offline   Top - Reply with Quote
Old 08-04-2007, 05:15 PM   #43
gregW
Forum Fanatic
Hi Tom,
I know how I would route that pattern, but after all the help and advice you've provided to me in the past it seems like I'm cheating
It's great to see you back on the forum!!
Tom
Greg
Old 08-04-2007, 05:55 PM   #44
Doyle
Forum Fanatic
Doyle is on a distinguished road
Hi Harry, Doyle here.
That was a very good presentation. I truly like the mistakes, that places me a notch or two higher than I was before reading your post. You mention if only a handful of people are interested, it would not be worth the effort. I consider myself a part of the second half of your sentence, in that I am a reasonable show of interest as I am close to 300 lbs, I should count for more than one.So that makes it all worth while.
You do good work, looking forward to reading more posts.
Take care
Doyle
Our tools and machines never take prisoners!
Doyle is offline   Top - Reply with Quote
Old 08-05-2007, 02:55 AM   #45
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Thanks for that Doyle.
Harry
Old 08-06-2007, 10:30 PM   #46
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Tom
I have been thinking about this design that Tom posted. I know how I would have done it then re read Harry's post and that would have been how I would have done it. I am looking forward to seeing how to do this one without pinning the pattern on top and following it with a guide to make a female pattern.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 08-07-2007, 12:12 AM   #47
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Me too Corey
I would make it this way, but I'm sure it's not the way they would made it..
Template made with the sticks and a cir. cut in to 4 parts for the corners then drop it on the router table and use a trim router bit to make the template..
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-07-2007, 04:46 AM   #48
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Originally Posted by bobj3
Me too Corey
Bj
Bj, you're making hard work of this, I did give clues saying it was very simple and no special tools required. It's obvious that there IS interest out there so I shall put you all out of you're misery. I must confess that when Tom came up with this answer for me all those years ago, I couldn't believe it!
First, make the basic template using the method shown and is in Tom's sticky in template guides. Next, cut a strip of MDF or whatever material you're using, the width of which will determine the radius. Now cut four pieces from the strip,the same size as the width and glue one in each corner. No you won't end up with squares in the corners of the pattern. Think about it, the guide won't go into the corners, it's too big, so it will ride around the points, believe me, Tom taught me.
I forgot to mention that I have drawn black lines to show where the glue joints are beneath the "Formica", wasn't I right in saying it was simple? Over time you will all get the hang of Tom's methods and will be designing you're own templates, and that will really give you a buzz.
question-harrysin-corner-pattern-template1.jpg  question-harrysin-corner-pattern-template2.jpg  question-harrysin-corner-pattern-template.jpg
Harry
Old 08-07-2007, 06:15 AM   #49
steveo
Forum Fanatic
steveo's Avatar
steveo is on a distinguished road
Pretty slick Harry, I'm starting to believe !
steveo
steveo is offline   Top - Reply with Quote
Old 08-07-2007, 09:27 AM   #50
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
As the late Al Johnson used to say "you aint seen nothing yet"
Harry
DC Question angus Lobby 3 03-31-2008 08:29 PM
Half Blind Router Template Question stevek433 Introductions 4 03-01-2008 12:17 PM
a member of 2 years but never posted a question. Here goes...(PC 695/bosch table) routerron Introductions 4 09-19-2006 12:33 PM
Where do I post this type of question? RouterFool Introductions 1 03-30-2006 09:54 PM
Table Fence Question Bob Table-mounted Routing 7 12-06-2004 04:42 PM
