| Guide Bushings and Templates This is where to learn about the different types of guide bushings and how to use them, how to create templates, how to build a frame to hold your work piece, and how to combine them all to create a project. |
| | #51 | |
| Forum Contributer Supreme Forum King | Thanks Harry I think what got me was the Size, I was thinking big and you are talking about a small pattern I was thinking on top of a table top and you are talking about the size of a small box lid But now I got it and I can see how that would work great with the 40mm guide or the 1 1/2" Oak-Park one ![]() Thanks again Bj ![]() Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 08-07-2007 at 02:29 PM. | |
| | #52 | |
| Banned Supreme Forum King | Quote:
That's a COOL method of making the guide to form those curved corners! The size of the Guide being a Key part! COOL!! Will have to remember that one! Last edited by Joe Lyddon; 08-07-2007 at 12:16 PM. | |
| | #53 | |
| Retired Moderator Supreme Forum King | Quote:
Sweet Harry. I wasted company time today trying to figure it out. Then I come home and find an answer that is so simple yet so far from the complicated method going on in my head. AWESOME!!!! Thanks Harry for this. Corey
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ | |
| | #54 |
| Forum Contributer Supreme Forum King | Tom sent me these shots today which are far more detailed than what I supplied. Those not using metric, simply use the closest you can get in imperial. I'm sure you must be able to buy 12" steel rulers with metric down one edge and imperial down the other edge, they also usually have conversions on the rear. I'll post a couple of shots of a sample s/s ruler next
__________________ Harry |
| | #55 |
| Forum Contributer Supreme Forum King | I'll post a couple of shots of a sample s/s ruler next[/quote] And here they are.
| | #56 | |
corey
| | #57 | |
Harry, in one of your earlier posts in this thread you mentioned an inlay material. Are you going to fill the grooves with some material or are you meaning something else? Looking forward to seeing more of this kind of work! Corey
| | #58 |
| Forum Contributer Supreme Forum King | That's a good question Corey, I actually discussed this very thing with Mike this morning, I mentioned that I might investigate the possibility of adding colour to epoxy and apply it with a syringe, failing that I shall use inlay strips. Perhaps someone reading this might be able to help regarding adding colour to epoxy. I think that the lid could be made to fit that first box that I made using the Oak Park spacer jig, I'll finish and post my new little box first in a few days after the five coats of Danish oil have been applied and polished, it received the third coat this morning.
| | #59 |
| Retired Moderator Supreme Forum King | If you use inlay strips I assume then that you used a regular straight bit when you did the line carving.. I was thinking you used a round bottom but I guess not. Corey
| | #60 |
| Forum Contributer Supreme Forum King | It was a straight bit Corey, as I had intended to use inlay strips but now with the extra grooves it would be a long winded job, but one that I may still undertake.
| DC Question | angus | Lobby | 3 | 03-31-2008 08:29 PM |
| Half Blind Router Template Question | stevek433 | Introductions | 4 | 03-01-2008 12:17 PM |
| a member of 2 years but never posted a question. Here goes...(PC 695/bosch table) | routerron | Introductions | 4 | 09-19-2006 12:33 PM |
| Where do I post this type of question? | RouterFool | Introductions | 1 | 03-30-2006 09:54 PM |
| Table Fence Question | Bob | Table-mounted Routing | 7 | 12-06-2004 04:42 PM |
