Go Back   Router Forums > Routers > Guide Bushings and Templates
Guide Bushings and Templates This is where to learn about the different types of guide bushings and how to use them, how to create templates, how to build a frame to hold your work piece, and how to combine them all to create a project.
Thread Tools Display Modes
Old 08-06-2007, 08:21 AM   #41
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Originally Posted by harrysin
There's so much in those posts so I shall only mention a couple. The way Bj has progressed so quickly, I'm not sure if even Tom will have much more to teach. Corey, you handsome young thing, it looks like you're template is sitting below the edges of the box, don't forget that it must be slightly higher so that the router isn't restricted, packing under the jig or work-piece is the way to go, similarly, if the work-piece is taller than the box, add side pieces as Bj has done. Keep up the good work, I'm eagerly awaiting you're first project from this set-up Corey.
HI Harry, it definitely will work ... I just fit it to the whole thing but it will be easy enough to pin the stock in it and then get the thing up above the rails like you said. Thanks HArry!
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 08-06-2007, 04:27 PM   #42
cnse55
New Member
cnse55 is on a distinguished road
looks great
WW-tom
cnse55 is offline   Top - Reply with Quote
Old 08-06-2007, 04:28 PM   #43
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Corey
Here's some more snapshots just for kicks,,still in a hold pattern waiting for the hardware to show up, but I did play with the jig today and made one template...
Bj
This template is for the item below posted by Harry
http://www.routerforums.com/50233-post1.html
harry-tom-bobj-others-7148.jpg  harry-tom-bobj-others-7149.jpg  harry-tom-bobj-others-7151.jpg  harry-tom-bobj-others-7152.jpg  harry-tom-bobj-others-7153.jpg
harry-tom-bobj-others-7154.jpg  harry-tom-bobj-others-7155.jpg  harry-tom-bobj-others-7156.jpg  harry-tom-bobj-others-7157.jpg  harry-tom-bobj-others-7158.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-06-2007, 07:22 PM   #44
challagan
Supreme Forum King
challagan's Avatar
Thanks Bj. I see now. 1/4 mdf and one pass with a pattern 1/4 bit? Is the painters tape to help with tear out... ruffled edges etc.? Thanks for posting this!
Old 08-06-2007, 07:44 PM   #45
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Corey
The tape is so I can eye ball the template up but it will help with the rip out also.
Lets say I want the slot 1/2" from the edges ,all need to do is lock the blank down in place and then just move the template around in place and then lock it in place..
In that way I don't need to play around with the blank trying to get it in just the right spot..
The template can just be moved around and I can put it in the just right spot....I could used a pencil but this lid that's in the snapshot is done so to speak but it's going to get the Harrys pattern put in it..
I's going to use the Small cove bit that comes with the TurnLock systems, it's a neat bit and I don't have one like it in my stock of router bits..it's made for the letter kit and comes with it from MilesCraft..
I used a 1/2" trim bit to cut out the template, it's quicker than normal 1/4" bit plus I'm going to use the 3/4" brass guide and it should work fine in the corners...radius thing...
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-06-2007, 09:01 PM   #46
challagan
Supreme Forum King
challagan's Avatar
I got yah BJ. Have to check out that bit. Is it a cove bit or Roundnose/Corebox bit? Size?
Old 08-06-2007, 10:21 PM   #47
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Corey
The one I got with mind was a 1/4" diameter Core Box carbide bit
http://www.milescraft.com/router/1212SP.html
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-06-2007, 10:34 PM   #48
challagan
Supreme Forum King
challagan's Avatar
Originally Posted by bobj3
Hi Corey
Bj
Thanks Bj, have one of those from Eagle America it's in the pic I posted yesterday. It's the upper right hand bit. I read somewhere this weekend.. maybe on the Milescraft site that they recommend EA for replacement bits.
Old 08-06-2007, 11:29 PM   #49
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Bud
Looks more like this one,,, ▼ but I'm sure the one you have will work just fine
Core Box Bits #6415
2 flute, carbide tipped. Will plunge cut. For fluting, reeding, and carving.
Cuts a shallow profile.
http://www.mlcswoodworking.com/shops...s/bt_core.html
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-07-2007, 09:23 PM   #50
challagan
Supreme Forum King
challagan's Avatar
Bj, didn't know if you knew it or not but there is a pdf at the Milescraft site with other designs than are in the instruction booklet. You probably know it already but just in case you didn't, Here is the link:
http://milescraft.com/instruction/1204operational.pdf
