| Guide Bushings and Templates This is where to learn about the different types of guide bushings and how to use them, how to create templates, how to build a frame to hold your work piece, and how to combine them all to create a project. |
Thread Closed |
| | #21 |
| Forum Contributer Supreme Forum King | There's no stopping you Bj. I'm finding it hard to keep up with you. I don't have cutters like the ones you used so I shall improvise, but not 'till next week. Regarding sharpening cutters, because Tom uses his routers so much, in teaching and show demonstrations, he is forever having cutters sharpened, I don't know what he pays but it costs me between $7.00 and $10.00 Ozzie dollars which is very much cheaper than replacement cost. Now Bob, seeing that you have a metal lathe and have proven that there is merit in using skis, why don't you make a pair out of solid smooth rod, just reduce the diameter of the ends to the next lower thread size, ie; 3/8" rods reduce to 5/16" so there is a shoulder to retain a large washer, known here as a mud guard washer, it really does look better!
__________________ Harry |
| | Top - |
| | #22 |
| Forum Contributer Supreme Forum King | Bj. I have sent a "quick reply" and whilst it shows me as the last poster, it's nowhere to be seen. This is the second time in a few days that it has happened with posts to you. I have just sent a PM to Mike to see if he can find it floating about in the ether!
| | Top - |
| | #23 |
| Forum Contributer Supreme Forum King | It's me again, the "missing" post has mysteriously reappeared, and in spite of saying that I wouldn't attempt to make tiny feet till Monday, I felt that Bj. was daring me to have a go so here is my first effort, straight off the router, it's top, the largest surface measures just 3/8" square and after making another 3 should be suitable to fit on the last of my boxes. Because it is so small and my camera doesn't have macro, I had to blow it up quite a lot, then crop it, hence the poor photo.
__________________ Harry Last edited by harrysin; 08-24-2007 at 07:22 AM. |
| | Top - |
| | #24 |
| Retired Moderator Supreme Forum King | +Harry, I have noticed a few of those glitches in the last 2 days. BJ responded to a post yesterday and it wouldn't recognize that there was a reply. When I responded it then recognized it. Nice feets! Those are some real tiny feet and they look great. Definitely going to have to try this myself. Corey
| | Top - |
| | #25 | |
| Forum Contributer Supreme Forum King | Hi Harry Well I could make some solid smooth rods but they I would need to make 3 sets, short ones,med.ones,long ones, the full thread Acme full thread should take care of that with just one set that are 30" long.. all that I need to do is move the skis in or out to what I need...to a point...Not to sure what a mud guard washer is but I think it's the same as fender washer is in the states.. small hole in the center with a big OD size. i.e. 3/8"ID x 1 1/2" OD...the same ones I'm now using now.. ![]() I like the little foot you made by the way ,,, small ones can be tricky, they are so hard to clamp down... Bob & Rick did it a neat way, they ran the stock by on all 4 sides, then took it to the band saw and cut them to size.say start with 1 1/2" thick stock that's about 12" long stand it on end and run it by the bit 4 times, then cut off what you need...I think it was a standard molding bit...but then it's been 4 years or so..... Bj ![]() Quote:
| | Top - |
| | #26 | |
| Registered User Forum King | Corey, that's a real cool looking box. I have not done very many boxes, but I sure would like to give this one a try. What is the "Oz Site" Quote:
| | Top - |
| | #27 |
| Retired Moderator Supreme Forum King | Hi Rolf, that's the Australian WWking site: http://www.woodworkforums.ubeaut.com.au/index.php They have a ton of sub forums... one of them being a dedicated box making forum. Corey
| | Top - |
| | #29 |
| Forum Contributer Supreme Forum King | "Well I could make some solid smooth rods but they I would need to make 3 sets, short ones,med.ones,long ones, the full thread Acme full thread should take care of that with just one set that are 30" long.. all that I need to do is move the skis in or out to what I need...to a point.. What the heck Bj. you have more than enough routers to dedicate one to each size of ski!
| | Top - |
| | #30 | |
| Forum Contributer Supreme Forum King | Hi Harry Well that's true, but I'm running out of wall space for the jigs, they are now 5 deep hanging on the walls on Wed. I had to put in some LONGER screws to hold the jigs ,they are now deck screws that are 4 1/2" long...and with 5 to 6 jigs on each screw...on about 4" centers .... ![]() So I need to keep that in mind when I make a new jig... Bj ![]() ========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 08-25-2007 at 10:22 AM. | |
| | Top - |
Thread Closed |
| Cool place here! | Jigstik | Introductions | 7 | 04-10-2008 08:25 PM |
| Just plain cool. | kp91 | Lobby | 1 | 03-10-2008 10:34 PM |
| wow this is cool | unlimitedwoodworker | Woodturning and Lathes | 3 | 12-21-2007 10:59 AM |
| How cool. More great reading to keep me occupied | thumpik | Introductions | 4 | 07-29-2007 11:11 PM |
