| Guide Bushings and Templates This is where to learn about the different types of guide bushings and how to use them, how to create templates, how to build a frame to hold your work piece, and how to combine them all to create a project. |
Thread Closed |
| | #81 | |
| Forum Contributer Supreme Forum King | Say Good Night Harry ![]() protrusion=something that protrudes or projects. Had to look that one just to make sure we are both on the same track ![]() "but don't forget that the guide is recessed into the router base" = Well ,yes and no , Only down under Harry, most the guides that we use in the states are flush with the base of the router that's to say only the guide/ring part protrudes pass the router base .... ![]() http://www.leevalley.com/wood/page.a...000,51208&ap=1 http://www.harborfreight.com/cpi/cta...emnumber=95160 STICKS I picked this trick up from Bob R. & Rick R. (of the RWS shows) it's a neat way and fast way to make any template/pattern, the sticks can be any size or as long or as short as you want them to be...plus you don't need to cut them to fit the item you want to make, something like below.... ============== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 08-30-2007 at 06:29 PM. | |
| | Top - |
| | #82 |
| Retired Moderator Supreme Forum King | Very nice Harry as usual. Great looking lid. Always enjoy seeing pics of you at work! Corey
| | Top - |
| | #83 |
| Forum Contributer Supreme Forum King | OK Bj. after a good nights sleep I've been into my shed and taken a couple of shots, one with my steel guide, the other with "you're" type of brass guide, you will see that mine only 'sticks out' 1/4" and 'yours' an extra 1/8" at 3/8" Regarding the 4 stick method of routing a template, it's very cute but at the moment I'll stick to the saw table method and try the sticks some time in the future.
__________________ Harry |
| | Top - |
| | #84 | |
| Forum Contributer Supreme Forum King | Hi Harry hahahahahahahaha, no you'er brass guide sticks out 3/8" mind only stick out 1/4" hahahahahahahaha LOL they make many types,,, I have some that stick out 1/2" and some that are plastic that stick out 3/4" some stick out only 1/8" in the same size,,, I have about 8 sets ( 1/4" to 1" -1 1/2") and most of them are 1/4" stick OUTS But it's no big deal if they don't fit the job I'm doing they get stuck in the lathe and get quick chop job to what I need ![]() NOTE*** they bigger they are the more they stick out ,like most things in life.... LOL hahahahahahahaha ============== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 08-30-2007 at 11:46 PM. | |
| | Top - |
| | #85 | |
| Retired Moderator Supreme Forum King | Quote:
corey
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ | |
| | Top - |
| | #88 | |
| Forum Contributer Supreme Forum King | Hi Harry That looks great with the inlay,,, and it did fix one of the errors in the corner, great job,,,, what did it teach you about doing this way ?. not to use a cove bit ?, down cut it to deep ?, what type of wood did you use for the lid and what type of wood did you use for the lnlay... ?? But it sure looks neat ![]() ========== Here's one you may get a kick out off ![]() see snapshot below... The Boss said I want you to make a sign for me ,so I did,,, It's black ,I was going to paint it white with black letters but I think I'm going to just let it be, it hangs down over the side walk and it's about 6" 8" off the ground and It's the 1st thing you see if you are going to the front door,,,, Just for kicks ![]() ========== ========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 08-31-2007 at 11:56 AM. | |
| | Top - |
| | #89 | |
| Forum Contributer Supreme Forum King | Quote:
Things it taught me; narrower grooves, don't use plaster, it's too porous, use epoxy with added colour, applied with a syringe (no needle). The wood is once again Jarrah. When wood is given, it's not possible to stipulate what type is needed! When I get around to trying two part epoxy, I will use the slow hardening type and slightly overfill the grooves which hopefully surface tension will hold it in the grooves and when hardened, drop it on the belt sander. Those are my thoughts Bj. but feel free to try it first. By the way, this is the other side of the lid I posted yesterday!
__________________ Harry | |
| | Top - |
| | #90 | |
| Forum Contributer Supreme Forum King | Hi Harry "which error in the corner" Got Ya LOL LOL hahahahahaha LOL "use epoxy" = that's neat, I didn't think of that one and I will give it a go next one I make ......============== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 09-01-2007 at 01:48 AM. | |
| | Top - |
Thread Closed |
| Cool place here! | Jigstik | Introductions | 7 | 04-10-2008 08:25 PM |
| Just plain cool. | kp91 | Lobby | 1 | 03-10-2008 10:34 PM |
| wow this is cool | unlimitedwoodworker | Woodturning and Lathes | 3 | 12-21-2007 10:59 AM |
| How cool. More great reading to keep me occupied | thumpik | Introductions | 4 | 07-29-2007 11:11 PM |
