| Guide Bushings and Templates Discuss Dimensions for PC base and guides? in the Routers forums; This seemed like info that should be easily available in the forum, but a search didn't turn up any ... |
| New Reply | Quick Reply |
| | Thread Tools | Search this Thread | Display Modes |
| | #1 | ||
| Registered User |
This seemed like info that should be easily available in the forum, but a search didn't turn up any results . . . I would like to make a new sub for my PC 890 and since I have easy access to a waterjet, it seemed like an easy thing to do. Only thing is that I don't know what to program. So my questions are: Where are the screws located in a PC base? What ID and rebate diameter and depth do I use for a standard PC template guide? Many thanks for any info you can provide | ||
| | #2 | |||
| Forum Contributer Supreme Forum King |
Hi hokenpoke The easy way is just pull off the one that's on the PC 890 now ( the black one) then you will have all you need to make a copy of it.. ![]() ========= Quote:
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/...op_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html Last edited by bobj3 : 02-06-2008 at 02:21 PM. | |||
| | #3 | ||
| Registered User Supreme Forum King |
Hi, hokenpoke. Welcome to the forums. Bj is correct. Just use the existing plate as a template and take all needed measurements from that.
__________________ George | ||
| | #4 | ||
| Registered User Forum Geek |
RustyW made one for his... Routerbase
__________________ Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin 1937-2008 R.I.P. | ||
| Make Your Own Sub Base For PC Guides | RustyW | Guide Bushings and Templates | 8 | 09-19-2007 09:10 PM |
| 40mm Guides for Templates + more | bobj3 | Jigs and Fixtures | 30 | 07-22-2007 11:09 PM |
| Model 320.17542 and table routing | trap | Table-mounted Routing | 41 | 07-03-2007 11:37 AM |
| Hitachi M12V template guides? | vwmowery | General Routing | 6 | 08-31-2006 11:51 PM |
| choosing a base plate ... | reikimaster | Table-mounted Routing | 5 | 01-13-2006 10:37 PM |
All times are GMT -5. The time now is 04:55 PM. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 |
