| | #1 |
| Registered User | This seemed like info that should be easily available in the forum, but a search didn't turn up any results . . . I would like to make a new sub for my PC 890 and since I have easy access to a waterjet, it seemed like an easy thing to do. Only thing is that I don't know what to program. So my questions are: Where are the screws located in a PC base? What ID and rebate diameter and depth do I use for a standard PC template guide? Many thanks for any info you can provide |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi hokenpoke The easy way is just pull off the one that's on the PC 890 now ( the black one) then you will have all you need to make a copy of it.. ![]() ========= Quote:
__________________ Bj Last edited by bobj3; 02-06-2008 at 02:21 PM. | |
| | #3 |
| Registered User Supreme Forum King | Hi, hokenpoke. Welcome to the forums. Bj is correct. Just use the existing plate as a template and take all needed measurements from that.
__________________ George If you can't fix it with a hammer, you've got an electrical problem... |
| | #4 |
| Registered User Forum Geek | RustyW made one for his... Routerbase
__________________ A married man should forget his mistakes. There's no use in two people remembering the same thing! |
| Make Your Own Sub Base For PC Guides | RustyW | Guide Bushings and Templates | 8 | 09-19-2007 09:10 PM |
| 40mm Guides for Templates + more | bobj3 | Jigs and Fixtures | 30 | 07-22-2007 11:09 PM |
| Model 320.17542 and table routing | trap | Table-mounted Routing | 41 | 07-03-2007 11:37 AM |
| Hitachi M12V template guides? | vwmowery | General Routing | 6 | 08-31-2006 11:51 PM |
| choosing a base plate ... | reikimaster | Table-mounted Routing | 5 | 01-13-2006 10:37 PM |
