| | #1 |
| Registered User Jr. Member | I have a question. I have two sets of guide bushings. One I got from ebay and the other I picked up at a show. Anyway from time to time they won't stay tight in my router, they will come loose while I'm routing. Is it just cheap bushings (they are brass, and they do fit) Or could I be taking to much of at one time. They have done it when I use my leigh jig and when making sliding dovetails. HELP! |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Hat I have one or two brass guides, here's a little trick I use when one will not stay locked in place .. Take the ring nut and put some 60 grit sand paper on the work bench ( on some GLASS ) and rub the nut on the sand paper and do the same to the brass guide don't go over board with the sanding just ruff it up a bit , besure to do both sides on the ring nut....use a cross hatch pattern when you ruff it up.... ============
__________________ Bj Last edited by bobj3; 04-18-2008 at 06:32 AM. |
| | #3 |
| Registered User Forum Fanatic | Hi Hat (no pun intended) Before you go to BobJ's method, try cleaning off the threads on both pieces with some alcohol or laquer thinner. They may have had some lubricant applied to them, prior to your purchase, or at worst case design, the threads are just plain worn. If that does not work, then give BobJ's method a try. Joe Z.
__________________ JoeZ If you never made a mistake, you never tried anything
| | #4 |
| Registered User Forum King | One tip I read about is to use some plumbers Teflon pipe tape on the thread.
__________________ Pete I've cut it twice and it's still too short! But only at one end. |
| guide bushing size chart | mharwell01 | Guide Bushings and Templates | 16 | 03-19-2008 07:32 PM |
| Inlay Guide Bushing and base plate | Doyle | Portable Routing | 3 | 06-07-2007 09:25 PM |
| Guide bushing identification | Mike | Guide Bushings and Templates | 26 | 03-24-2007 09:57 PM |
| Guide Bushing Height??? | english | Jigs and Fixtures | 10 | 01-22-2006 05:13 PM |
