Go Back   Router Forums > Routers > Guide Bushings and Templates
Guide Bushings and Templates This is where to learn about the different types of guide bushings and how to use them, how to create templates, how to build a frame to hold your work piece, and how to combine them all to create a project.
Thread Tools Display Modes
Old 04-17-2008, 03:57 PM   #1
Hat
Jr. Member
Hat is on a distinguished road
Default Guide bushing
I have a question. I have two sets of guide bushings. One I got from ebay and the other I picked up at a show. Anyway from time to time they won't stay tight in my router, they will come loose while I'm routing. Is it just cheap bushings (they are brass, and they do fit) Or could I be taking to much of at one time. They have done it when I use my leigh jig and when making sliding dovetails. HELP!
Hat is offline   Top - Reply with Quote
Old 04-17-2008, 06:06 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Hat
I have one or two brass guides, here's a little trick I use when one will not stay locked in place ..
Take the ring nut and put some 60 grit sand paper on the work bench ( on some GLASS ) and rub the nut on the sand paper and do the same to the brass guide don't go over board with the sanding just ruff it up a bit , besure to do both sides on the ring nut....use a cross hatch pattern when you ruff it up....
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 04-17-2008, 07:24 PM   #3
cbsjoez1935
Forum Fanatic
cbsjoez1935 is on a distinguished road
Hi Hat (no pun intended)
Before you go to BobJ's method, try cleaning off the threads on both pieces with some alcohol or laquer thinner. They may have had some lubricant applied to them, prior to your purchase, or at worst case design, the threads are just plain worn. If that does not work, then give BobJ's method a try.
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline   Top - Reply with Quote
Old 04-18-2008, 04:54 AM   #4
nzgeordie
Forum King
nzgeordie's Avatar
nzgeordie is on a distinguished road
One tip I read about is to use some plumbers Teflon pipe tape on the thread.
Pete
I've cut it twice and it's still too short! But only at one end.
nzgeordie is offline   Top - Reply with Quote
guide bushing size chart mharwell01 Guide Bushings and Templates 16 03-19-2008 08:32 PM
Inlay Guide Bushing and base plate Doyle Portable Routing 3 06-07-2007 10:25 PM
Guide bushing identification Mike Guide Bushings and Templates 26 03-24-2007 10:57 PM
Guide Bushing Height??? english Jigs and Fixtures 10 01-22-2006 06:13 PM
