Go Back   Router Forums > Routers > Guide Bushings and Templates
Rate This Thread - Calculating template sizes.
Thread Tools Display Modes
Old 05-10-2008, 06:38 PM   #1
ceetee
New Member
ceetee is on a distinguished road
Default Calculating template sizes
Hi everyone - I'm new to Router Forums but wanted to see if someone will give me some needed info. I want to make a circular jig to put on top of a 12" round board that will allow me to leave a 1/8" wide lip on the board, how to I calculate the diameter of the round jig? Like my memory, the formula I once knew is long gone! What I'm attempting to do is make some lazy susans with the lip idea. That should prevent items from falling off the top surface - especially if it should get spun too fast. I would like to use a 1/2" straight bit and corresponding bushing. After routing the circular groove, I'll find a way to remove the rest of the top surface - leaving only the lip sticking up. Help!
No one is ever too old to learn or practice good safety!
ceetee is offline   Top - Reply with Quote
Old 05-10-2008, 07:41 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi ceetee
Here's just one way to get the job done quick and can be used over and over..
Just chuck up a 1/2" router bit and put the 3/4" brass guide in the router base, turn the jig with the router plunged down, put in the slot outside slot then use the other holes or slot to plow out the center...
Bj
Old 05-10-2008, 08:06 PM   #3
ceetee
New Member
bobj3 - Thanks for the quick reply. Maybe I should have been a bit clearer. I know there is a woodworker's formula that involves the diameters of the bushing and bit. So, I have a piece of wood that's been made from several pieces which have been biscuited and glued together. The finished size is 12" in diameter. I would like to cut a circular jig out of some 1/2" thick ply I have. I'll clamp the circular jig on top of the 12" round finished piece I have and I want to route around the jig using a 5/8" bushing and 1/2" straight cutter. I'd like to calculate the diameter of the jig before cutting it out. My intent is to leave a 1/8 to 1/4" wide lip around the entire top of the finished round board. I used to know how to calculate the diameter of the jig I need to cut out with a jigsaw - but my memory is on vacation. Thanks again!
Old 05-10-2008, 09:15 PM   #4
Hamlin
Supreme Forum King
Hi,
If you're wanting to leave an 1/8" to a 1/4" lip, do as Bj suggested. Use a 3/4" bushing/guide or larger with your 1/2" bit. For routing out the center part, I'd also suggest using a dish cutter bit, would leave a smoother finish.
Ken
(On temporary leave of abscense)
"A VETERAN"
"Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown
Old 05-10-2008, 09:19 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI
Got ya, but with the jig, it will do all the work for you ,, no need to calculate the diameter , use the jig to cut the circle out,plus put the trim lip in place all with one jig, just mark the center point, screw the jig down , to get the job done..
But here's a link that may help
http://www.routerforums.com/email-ro...ing-chart.html
calculating-template-sizes-template-1.jpg  calculating-template-sizes-template-2a.jpg  calculating-template-sizes-template-3.jpg
Bj
Template Guide sizes mftha Guide Bushings and Templates 11 06-04-2008 05:35 PM
Part 2 - template sizes ceetee Guide Bushings and Templates 0 05-11-2008 09:56 AM
Half Blind Router Template Question stevek433 Introductions 4 03-01-2008 11:17 AM
Calculating door sizes lablover Table-mounted Routing 14 05-23-2007 12:47 PM
Hitachi M12V template guides? vwmowery General Routing 6 08-31-2006 11:51 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
