Go Back   Router Forums > Routers > Guide Bushings and Templates
Rate This Thread - Help with bushing & pattern size.
Thread Tools Display Modes
Old 06-04-2008, 06:16 AM   #1
fdcox
Member
fdcox is on a distinguished road
Default Help with bushing & pattern size
I want to make the following, but I am not sure how to make the right size pattern for this and what size bushing and bit to use.
I saw this (marble game) on the web; it is going to have Plexiglas on both sides with rails to flip over to let the marbles drop
fdcox is offline   Top - Reply with Quote
Old 06-04-2008, 09:00 AM   #2
rstermer
Sr. Member
rstermer is on a distinguished road
fdcox- I am certainly no expert, but, if you are in the US, Harbor Freight has a set (cost $19.99) which contains a 21/32" I.D. and 3/4" O.D. bushing which would seem to do the trick as your 5/8" cut is 20/32" and the shank on the bit is usually 1/4 or 1/2" so will also fit. Just check to make sure you don't have any interference when you chuck everything up.
rstermer
rstermer is offline   Top - Reply with Quote
Old 06-04-2008, 09:17 AM   #3
rstermer
Sr. Member
fdcox- Another thought, as to laying out the pattern, you could draw it on SketchUp, with a 3/4" wide groove, print it out, glue the printout to a piece of hardboard and cut it out on the scroll saw (best way) or using a jig saw (definitely second best, not near as much control). Once you did that, the 3/4" template guide would fit right into the groove and you could route it out (although since I try to minimize dust, I would probably cut out most of the waste first using the scroll saw). Whether you attach the template guide directly to the workpiece or use a frame (see Template Tom's excellent tutorial) would depend on how many you were going to make. In any event a backer board would be required as you are routing all the way through your workpiece, unless of course you like the idea of a nice zig-zag groove inlaid into the top of your workbench! Please post some plans and a picture when you get it done. I'd like to see how it comes out!
rstermer
Old 06-04-2008, 10:39 AM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi fdcox
This is what I would suggest,,,marble games have been around along time I would stop by a toy store like Toys are Us, and pickup a pattern made with plastic ,then use it with the brass guides to make your mable game in wood....or to make your template quick and easy...
http://marbleboardgames.com/
http://www.google.com/search?hl=en&q...=Google+Search
Amazon has a listing for over 1000 of them...
Old 06-05-2008, 02:22 AM   #5
fdcox
Member
Thanks for the suggestions, for the first one I did it with a scroll saw as suggested, turned out just fine... thanks
Answer to template size problem ceetee Guide Bushings and Templates 5 05-14-2008 05:31 PM
guide bushing size chart mharwell01 Guide Bushings and Templates 16 03-19-2008 07:32 PM
Guide bushing identification Mike Guide Bushings and Templates 26 03-24-2007 09:57 PM
What size is it? Thread size... mountainguy Tools and Woodworking 1 08-20-2006 02:02 PM
Inlay Problem boxer Tools and Woodworking 7 04-18-2006 10:10 AM
