| | #1 |
| Registered User New Member | This is a good subject for my first post. My favorite tool story is the sort of user who says, "No worries mate, I've been woodworking for 30 years and I still have all eight fingers." Well I've been doing it for quite a bit less time and am still ponering my first router. I've been doing jobs with a smaller tool which takes router bits with 1/4 shanks. It came as a kit from the Menard's home store in US. I've been able to use this gizmo with zip bits to do cut offs, chamfers and free hand flush trims and rabbets. This is all in the speaker building hobby. The topic of concern is making flush trim for oddly squate shaped audio speakers. I've done this free hand on the surface. But the accurate procedure is to use the flush trim bit mounted in a table, make the pattern and then do the additional steps to get the jig made. This has been covered in a thread I started at diy audio forums called "flush mounting drivers, the whole story." The thread is made for both round and square speakers and also the process of making round driver holes. When using the table setup, the original the piece is mounted to stock and the edge of the piece (metal flange) is used to get the pattern. I've looked through the info here and see illustrations of the procedure. There's also a source in a speaker magazine called audioXpress. My question is on guiding the work to the mandrel/turning bit. I've seen here where hold downs are used to keep hands away from blades in close corner work. What is the preferred method for this? |
| | #2 |
| Marine Engineer Forum King | lon, Let me see if I understand your question. Are you asking how do you guide the stock you are holding into a spinning bearing guided router bit? The answer is to use a starting pin. The starting pin (or Fulcrum pin) gives you something to hold the wood against as you pivot the stock into the cutter and on to the bearing. This helps prevent the stock from getting pulled out of your hands as the bit begins to cut, or worse yet, pull you hands toward the bit. Once the stock is riding on the bearing you can work away from the starting pin. Hope this helps, Doug
| | #3 |
| Forum Contributer Supreme Forum King | I did reply to your post dated 13th June saying that this link to an earlier post of mine should give you a basic understanding of routing with template guides. http://www.routerforums.com/40472-post1.html
__________________ Harry |
| | #4 |
| Registered User New Member | What happened to my reply that mentioned the router book I found that shows these things? I made a response to this yesterday. I also grabbed the pdf on pattern making but didn't print it to paper yet. The book is: by Bill Hylton on Router Tables. Word: I think my post from yesterday got dropped because there was a url in it. Why can't those be included in text messages? |
| | #5 |
| Registered User Forum Geek | URL's can be included after so many posts are made, think it's about 10. Spam control measures. As for your post getting dropped, it's happened to me as well... actually think it's me hitting the back button before I hit the final post button. Brian
__________________ A married man should forget his mistakes. There's no use in two people remembering the same thing! |
| 1000 bucks in new tools. what to get? | kleptic | Tools and Woodworking | 10 | 06-13-2008 01:24 AM |
| is it possible to woodwork without 20k in tools? | kleptic | Starting Off | 14 | 03-23-2008 02:35 AM |
| the truth about milwaukee an aeg tools | toolsreview | Tool Reviews | 3 | 01-13-2008 07:05 AM |
| Japanese Carving Tools | KoLdArKnEsS | Tools and Woodworking | 1 | 09-15-2006 07:23 AM |
| Which tools for most jobs | Bob | Tools and Woodworking | 9 | 12-26-2004 08:00 PM |
