| Guide Bushings and Templates This is where to learn about the different types of guide bushings and how to use them, how to create templates, how to build a frame to hold your work piece, and how to combine them all to create a project. |
| | #1 |
| Registered User Forum Geek | I’m a complete rookie when it comes to inlay work but I would like to start exploring it. Looking at woodpeckers they have some nice (and expensive) kits and templates available. http://www.woodpeck.com/butterflytemplate.html If I get a set up like this (or something similar) do you use this with a plunge set up? It would seem that a plunge base would cut the inlay more accurately than dropping a spinning bit into the template. Next question… Is there a base that works with the Bosch 1617? I don’t think these standard bushings will just screw onto the Bosch’s plunge base. |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Nick Inlay patterns.. You can make your own set very easy but if you don't want to take the time you can buy a set,,, Clear plastic base plate to take on the brass guides, the clear plastic one will let you see what's going on under the router base when you are doing inlays...that's real plus or you can get a set of guides that fit the Bosch and will let you put in the standard 1 3/16" PC guides but I don't recommend it, I have one and it sucks. http://www.mlcswoodworking.com/shops...mpguide_anchor inlay patterns http://www.mlcswoodworking.com/shops...terns%20anchor http://us.oak-park.com/catalogue.html?list=PAT-- You can use a plunge router or a fixed base, the plunge type makes the job a bit easyer but both can do a fine job when it comes to inlays... ===
| | #3 |
| Forum Contributer Supreme Forum King | Nick., have you considered ready made off the shelf inlays as shown here. There is a wide selection of strips and round, square & diamond shape inserts available downunder, so they must be available everywhere. The templates are very easy to make as you will see if you peruse my gallery, just a cheaper alternative to your original idea.
__________________ Harry |
| Colt plunge base | bobj3 | Jigs and Fixtures | 19 | 04-01-2008 08:54 PM |
| Inlay Guide Bushing and base plate | Doyle | Portable Routing | 3 | 06-07-2007 10:25 PM |
| anyone pull the springs out of a Porter Cable 890 plunge base? | paulcomi | Tools and Woodworking | 8 | 04-23-2006 06:26 PM |
| Pitting in PC plunge base | DONALD | Tools and Woodworking | 5 | 12-04-2004 11:36 PM |
| Converting fixed base to plunge base. | -Sam- | Portable Routing | 4 | 09-30-2004 04:53 PM |
