What Gauge Bolts For Jigs - Router Forums
 11Likes
post #1 of 13 (permalink) Old 01-10-2017, 08:35 AM Thread Starter
Default What Gauge Bolts For Jigs
What gauge hex and carriage bolts do you typically use for your woodworking jigs. Not heavy duty construction connections. More like the stuff for hold downs, slot and T track type attachments. I've seen design instructions that use 3/8" bolts but based on strength charts 1/4" would have been strong enough. Is it the appearance of more strength?
JIMMIEM is offline
post #2 of 13 (permalink) Old 01-10-2017, 08:41 AM
1/4'' grade 5 will work quite well....
Cherryville Chuck likes this.
post #3 of 13 (permalink) Old 01-10-2017, 08:56 AM Thread Starter
Thank You!!!
JIMMIEM is offline
post #4 of 13 (permalink) Old 01-10-2017, 09:41 AM
First Name: pat
6M, 10-24, 1/4-20, & the oak frame is held together with 5/16-18. It's application dependent.
Quillman is offline
post #5 of 13 (permalink) Old 01-10-2017, 01:28 PM
1/4" is usually good enough and usually cheaper because of being so plentiful but as Pat says, it can be application dependent. Rarely is strength that much of an issue.
roxanne562001 likes this.
post #6 of 13 (permalink) Old 01-10-2017, 01:54 PM
kp91's Avatar
First Name: Doug
Mostly 1/4 and 5/16
MT Stringer and TenGees like this.
1 John 1:9
Fredericksburg, VA
My daughter amazes me https://houndsathazelwild.wordpress....houndgold2016/
kp91 is online now
post #7 of 13 (permalink) Old 01-10-2017, 02:47 PM
MT Stringer's Avatar
Originally Posted by kp91 View Post
Mostly 1/4 and 5/16
Mee too.
Daikusan likes this.
MT Stringer is online now
post #8 of 13 (permalink) Old 01-10-2017, 02:49 PM
First Name: Richard
Me 3
papasombre and MT Stringer like this.
Shop guy is online now
post #9 of 13 (permalink) Old 01-10-2017, 02:53 PM
Knothead47's Avatar
Grade 3, IMHO, would be OK. Grade V is somewhat overkill. For my use, 1/4-20 is used for T-Track and other things.
John T.
It's a matter of perception.
Deduction: I have it.
Loophole: You have it.
Knothead47 is offline
post #10 of 13 (permalink) Old 01-11-2017, 09:46 AM
roxanne562001's Avatar
First Name: Roxanne
I use 1/4" bolts for jigs and fixtures . Here in the US I find the best place to buy bolts is Tractor Supply Co. They sell bolts in Bulk by the pound. They have grade 3 through grade 8 bolts at very reasonable prices compared to the big box stores.
kp91 likes this.
roxanne562001 is offline
Human Verification
Incra 1000HD Miter gauge. Need help please hawkeye10 Tools and Woodworking 29 06-14-2016 09:35 AM
About My New Osborne Miter Gauge Jerry Bowen Tools and Woodworking 6 06-18-2012 03:14 PM
Kreg Miter Gauge vs. Incra Miter Gauge Jerry Bowen Tools and Woodworking 8 06-04-2012 09:58 AM
The Problem With The Incra Miter Gauge Jerry Bowen Tools and Woodworking 16 05-31-2012 10:25 PM
Do you use a mitre gauge on a table? neoshed Table-mounted Routing 10 11-01-2007 09:32 PM
