Thread Tools Display Modes
Old 04-07-2005, 08:53 PM   #1
hardel
New Member
hardel is on a distinguished road
Default Elliptical archway Problems
Hi All,
This is coming from a newbie to using a router !!!!
I am atempting to make mouldings for my archway and I am having a problem. A little background..... I produced a computer drawing of the archway complete with mouldings which create the pillars and the elliptical mouldings for around the top. I then proceeded to make templates from the line drawings to give me the elliptical shape I required. I then made 3 bases of different diameters for my router. These Bases were used to offset the grooves I routered into the mouldings to dress them up. I used the templates (as mentioned earlier) as a guide for the router to follow. Thing is I made the elliptical shaped mouldings before I sheeted in the opening and now the mouldings do not fit the opening, ( remember I am a NEWBIE ...be kind and try not to laugh..I know it's hard!) Any ideas on how I should proceed from here to make the new mouldings. I think I can trace the shape of the opening to cardboard, but how do I cut the outside edge of the moulding? Best way to transfer from cardboard to make template? etc.
Sorry for being long winded.
Harold
hardel is offline   Top - Reply with Quote
Old 04-07-2005, 10:44 PM   #2
GoonMan
Forum Geek
GoonMan's Avatar
First Name: Randy
GoonMan has a little shameless behaviour in the past
Hello hardel, Welcome to the Forum
I believe if you can post a print or pic of what you are trying to do then these great people here can help you.
Regards
Randy
PC Support Forums, Free on line virus Scan, The Parasite Fight,
Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~
GoonMan is offline   Top - Reply with Quote
Old 04-08-2005, 08:34 AM   #3
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi, Harold:
Welcome to the Forum. I think you kind of put the cart before the horse on this one,
but everyone of us has done that also from time to time. I suggest that you make your cardboard template from the arch, which I trust is not going to change. Transfer the template to some 1/4" or 1/2" sheet stock. Size it so that you can use a guide bushing to make the cut. You may want to adjust the template size so that you can use bushings that would allow you to offset the cuts that way you can make the design inside the moulding by using different size bushings. It is important to have the template as smooth as possibl sine the router will follow any defects.
Hope this helps you out.. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 04-08-2005, 04:45 PM   #4
hardel
New Member
Thanks for your prompt reply GoonMan & Woodnut65!
I have attached a drawing and picture of the opening. You're right Woodnut65, the router found every imperfection in my previus template and it showed.
Hardel
Old 04-08-2005, 04:46 PM   #5
hardel
New Member
Sorry I could not attach the picture. Probaly to big 300k.
Hardel
Old 04-08-2005, 05:59 PM   #6
-Sam-
Forum King
-Sam-'s Avatar
-Sam- is on a distinguished road
hardel,
Can you shrink the picture, then send it?
Sam
Retired Forum Moderator
Refer a friend to RouterForums.com!
-Sam- is offline   Top - Reply with Quote
Old 04-09-2005, 11:08 AM   #7
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Originally Posted by hardel
Hi All,
Harold
The moldings fit the opening before you sheeted it in, right?
Do you have guide bushings? Is the router bit centered on the bases you made and did you use these to cut the shape or just put grooves in the molding? Can we see some photos?
Rick and Bob
The Router Guys
Old 04-11-2005, 11:19 AM   #8
hardel
New Member
Hi Guys,
I do not have guide bushings. The router bit was not centered exactly on the bases, but extremely close (probaly not good enough). The bases were used just for the grooves ... and while routing the grooves I always used the same area (which I shaded in) of the bases to follow the template this way where the base was not exactly centered the bit should be in the same place for each pass.
I am having a hard time attaching pictures. I reduced both pictures to approx. 80k each and still no luck. I pasted them into a word document and that seems to have work I think.
Harold
Old 04-11-2005, 11:23 AM   #9
hardel
New Member
It seems as though the pictures did not go through again.
Harold
Old 04-11-2005, 12:53 PM   #10
reible
Supreme Forum King
reible's Avatar
Harold
Hi, take a look at this link and maybe that might help you with the image problem:
www.routerforums.com/showthread.php?t=526
One other thing might be the size, if you can size them to 640 x 480 I know for sure that size works.
If none of this works contact me via email and I will post them for you.
Ed
Introduction and questions re: kickback problems BrettW Introductions 2 05-05-2008 08:56 PM
Porter router 7518 problems (URGENT!!!!!!) marc.brunet.gagne Introductions 2 04-30-2008 09:52 PM
Problems with cabinet door rails... Coon Table-mounted Routing 11 04-17-2008 12:15 PM
Internet Explorer Problems JamesEMc Lobby 3 04-09-2005 10:43 PM
Problems Logging in Glenmore Lobby 1 02-15-2005 12:11 PM
