| | #1 |
| Registered User | Am duplicating 'knuckle joints" (split or bridal joints with a 1/4" roundover) from Paul Levine's "Contemporary Woodworking Projects". Since these joints have to be right on, he uses a 7/8" guide bushing and a 2" straight bit to clean up the joint after bandsawing/drilling out most of the waste. He suggests a 3/8" plywood template as a guide. My problem is this: I have only found 3/4" guide bushings available and all have 9/16" collars which extend below the bushing. Since the template is 3/8" and the height of the collar is 9/16" it seems logical that the bit will not trim the 3/8" of stock just under the template. Am I seeing this correctly and if so, what's the solution? By the way, nice to join the forum and thanks in advance. English |
| | #2 | |
| Registered User Forum Fanatic | Quote:
steveo | |
| | #3 |
| Registered User Forum Geek | Hi, English: Guide bushings that I have, are 1/4" below the bushing. If your bushing is longer than 3/8" you will have to make the temple thicker, like 3/4 ". Apparently the person writing the article had bushings that had shorter sleeve length. Using a thicker bushing will allow you to cut the material below the template if you are using the router hand held. If using the router in a table the template is on the bottom and the material will be above it. The important thing is the length of the bit, since ti must go down 3/4" plus the thickness of your material.. Hope this helps.. Woodnut65 |
| | #4 |
| Registered User | I had a similar problem, but by shopping different stores, was able to find bushings of different heights. Note that different sources use different threads on the bushing collar. |
| | #5 |
| Registered User New Member | I encountered this problem the first time I tried to use my Porter-Cable bushings, i.e., most of them extended below the template guide. I solved the problem by ordering a set of WOODRAFT bushings (#144625) . The all protrude 0.24 " and work with any stock 1/4 " or larger. Joe |
| | #6 |
| Registered User New Member | If I understand you correctly your bushing is too long. When I have run into this problem I trim the bushing to the desired length. I use 1/4 inch masonite for some temlates so I do a lot of trimming of bshings. DALE |
| | #7 | |
| Registered User Forum King | Quote:
Tom | |
| | #8 | |
| Registered User New Member | I have run into this lots of times. I have used masonite for lots of templates and 1/4" acrylic most of the time these days. A few companies carry collars designed for 1/4" templates. I use Porter Cable routers in my shop and use the Porter Cable collar sets, which are too long. I just ground them down on the grinder and I'm good to go. Quote:
| | #9 |
| Marine Engineer Forum King | I had a set of bushings I picked up at a woodworking show, and they too were just a hair longer than a 1/4 of an inch. A quick touch on the belt sander and they were perfect! (just make sure you remove any sharp burrs afterwords) I now use a lee-valley set for the larger baseplate hole than the porter cable guides and they work perfectly and are cheap!
| | #10 |
| Registered User Sr. Member | let me throw you guys a curve for a second. Can you use these bushings with a bull nose bit? thanks, Tally |
| guide bushing size chart | mharwell01 | Guide Bushings and Templates | 16 | 03-19-2008 07:32 PM |
| Inlay Guide Bushing and base plate | Doyle | Portable Routing | 3 | 06-07-2007 09:25 PM |
| Guide bushing identification | Mike | Guide Bushings and Templates | 26 | 03-24-2007 09:57 PM |
| Guide Bushing Calculations | tdinovo | Portable Routing | 5 | 10-29-2005 11:17 PM |
