Thread Tools Display Modes
Old 05-23-2005, 12:04 PM   #1
jccarter
jccarter is on a distinguished road
Default off center mortise
i seen them use the router to center a mortise,but all mortises are not in the center what jig is out there to put it where your band on a table sets back from the edge
jccarter is offline   Top - Reply with Quote
Old 05-23-2005, 02:16 PM   #2
kp91
Forum King
kp91's Avatar
First Name: Doug
The easiest way to cut and offcenter mortise using a router jig that centers up on the stock you are cutting is to add a shim to the side of the stock you are mortising. What the shim will do is offset the mortise 1/2 of it's thickness.
Basically, if you are cutting a mortise in a piece of 1-1/2 inch stock using a jig that centers on the stock, your mortise will be on the centerline, or 3/4 inch from the edge. If you add a 1/2 inch thick shim, your mortise will be cut on the centerline of a 2 inch piece, or 1 inch from the edge. This will give you a mortise 1/4 inch of centerline.
If this is still clear as mud, let me know and I'll try to come up with a sketch or something
1 John 1:9
kp91 is online now   Top - Reply with Quote
Old 05-24-2005, 09:59 PM   #3
template tom
Forum King
Construct a simple jig where you can use your template guide with the router and locate the mortice wherever you wish
Tom
Next project: Entertainment center zbhover Tools and Woodworking 7 01-21-2008 01:47 PM
Rounded Mortise & Squared Tenons? Nickbee Table-mounted Routing 15 01-16-2008 09:11 PM
How to do Mortise and Tenon? JDługosz Jigs and Fixtures 26 10-21-2007 02:17 PM
Rolling Mortise Jig - the test simplenik Table-mounted Routing 9 07-23-2007 11:54 AM
Finding Dead Center cfm Jigs and Fixtures 1 11-13-2004 11:22 AM
