| | #1 |
| Registered User New Member | i just purchased the 7 inch plate and the mortising kit work ok. however im making a table that has 2 inch legs and i dont want the mortise in the center. the jig i made for the 3/4 will not let you shim enough to get the mortise where i want it,do i make a wider jig |
| | #2 | |
| Registered User Forum King | Quote:
Tom | |
| | #3 |
| Registered User Forum Geek | The way to cut mortices off center is to add temporary stock to the side that the mortice will be close to. Adding an inch to one side of a 2 inch Leg would offset by 1/2" toward the out side of the 2" leg. Further shimming on one side of the leg will result in 1/2 the thickness of the shim toward the outside of the leg. Hope this helps.. Woodnut65 |
| Making Mortises ? | Donzoid | Table-mounted Routing | 8 | 11-27-2007 05:01 PM |
| Thin stock to 1/8 inch on Planer | ACV | Tools and Woodworking | 6 | 10-22-2007 12:13 AM |
| An alternative way to hold stock | harrysin | Guide Bushings and Templates | 5 | 02-18-2007 03:47 PM |
| Desimal inch and fraction inch | mbsn | Tools and Woodworking | 6 | 09-14-2006 01:30 PM |
| 1/4 inch collet extensions? | rwy | General Routing | 2 | 05-02-2005 12:07 PM |
