Help
incra jig right angle
This is a discussion on incra jig right angle within the Jigs and Fixtures forums, part of the Routers category; I shall take some photos and post them. The nylon and other plastic are offcuts ...
Old 06-22-2009, 11:59 AM   #11 (permalink)
Mike Wingate's Avatar
First Name: mike
Mike Wingate is on a distinguished road
Report Post Report This Post!
I shall take some photos and post them. The nylon and other plastic are offcuts sourced from a local stockist, sold by weight. I am using some black nylon for my Digital height gauge
Mike Wingate is offline
Old 06-22-2009, 05:46 PM   #12 (permalink)
oldnewbie's Avatar
First Name: Neal
oldnewbie is on a distinguished road
My Pusher block doesn't have the part to hold it to the fence. Is this a later inovation? Looks like it would be very useful. Is there possibly an update add-on that can be purchased?
Thanks, Neal
Remember that “…you are a chosen generation, a royal priesthood, a holy nation, His own special people, that you may proclaim the praises of Him who called you out of darkness into His marvelous light.”
1 Peter 2:9
oldnewbie is offline
Old 06-22-2009, 05:56 PM   #13 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
HI Neal
It's shop made add on,,just like the handle,,,it sure works great to keep it to the fence all the way down the pass and on the pull back pass ,easy to make with two flat head screws some nuts and some MDF stock...
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 06-23-2009, 07:12 AM   #14 (permalink)
First Name: mike
Nylon sliders.With sacrificial strip.
Old 06-23-2009, 07:14 AM   #15 (permalink)
First Name: mike
Default 2 more of the same
Nylon sliders and sacrificial strip stuck on with double sided tape.
Old 06-23-2009, 10:28 AM   #16 (permalink)
Noob's Avatar
First Name: Paulo
Noob is on a distinguished road
I have a question on the right-angle slider, and it's not too off-topic. Incra recommends clamping your wood to it with wooden clamps like these: HF wood clamps LINK
Do you actually use that one,or would an f-style clamp work? By the way, it has t-slots on it and I was wondering if a toggle clamp would hold the board sufficiently, like these: 500lb horizontal toggle clamp LINK or 500 lb vertical toggle clamp LINK
Noob is offline
Old 06-23-2009, 11:22 AM   #17 (permalink)
First Name: mike
I use a pair of these QR clamps, front and backing boards spread the pressure.
Old 06-23-2009, 12:42 PM   #18 (permalink)
bobj3's Avatar
Hi Noop
I use just a 2" or 3" C-Clamp with a wood pad on it (with sand paper,glued in place) so it can't put marks on the stock with the nasty little ring I made a pair like the OP type with big wooden handles ( 2'' diam.) the wooden type clamp is always in the way for me...
No real room for the toggle type clamps..
Part Finder
Bob J.
Old 06-23-2009, 01:52 PM   #19 (permalink)
First Name: mike
I think HD Toggle clamps may distort the carrier face.
Old 06-29-2009, 01:27 PM   #20 (permalink)
hgporter is on a distinguished road
Default Tape or Solid Runners?
...You can save a buck or two with the tape...or get the stock to make the blocks from the same.see below ....
UHMW Plastic Sheets and Strips
I didn't choose tape based on economy. I chose it because I wanted to make everything that slides, slide easier. Adding tape to the bottom of everything that contacts the table insured each item stayed in perfect alignment with each other.
You certainly could replace the hardwood runners with machined UHMW blocks, compensating for the amount the fence was raised. I don't see a need for solid block runners because the tape wear is almost negligible. I'm betting the 0.030 tape could easily outlast me.
Once you have the tape, you'll find other applications for it. A couple of strips on every jig that slides on a table works wonders.
Good, Fast, Cheap —*Pick any Two!
hgporter is offline
Hook Angle pemdas86 Starting Off 6 01-27-2009 08:20 PM
Dovetail jig or Incra system for table use? AlanZ Jigs and Fixtures 10 01-06-2009 08:29 PM
Incra LS Positioner and Bosch RA1181 table thistlefly Table-mounted Routing 3 01-05-2009 06:58 PM
Jointech Vs Incra Router Table fences KWD General Routing 2 10-24-2008 07:21 PM
Incra track/Featherboard tip LonePalm Tools and Woodworking 2 03-14-2008 07:30 PM
