Thread Tools Display Modes
Old 06-02-2005, 05:08 PM   #1
hawker44
New Member
hawker44 is on a distinguished road
Default Pocket hole jig
I have been searching for a home made pocket hole jig for use on a router table. Can anyone help? I have seen plans for one in a mag. once but can't find it.
hawker44 is offline   Top - Reply with Quote
Old 06-03-2005, 01:32 AM   #2
Frank Hagan
Frank Hagan is on a distinguished road
I haven't seen one that can be used on a router table. The magazine "450+ best-ever Shop Tips" put out by the editors of Wood Magazine has a jig for freehand use of a router. Its a board 7 1/2" long by 3 1/2" wide, with a 10° slope starting 1 13/16 from the top and ending at the other edge (where it is only 1/4" thick). There is a 1/2" slot 4 1/4" long centered in the angled portion of the wedge. At the thick end, a 3/8" piece of plywood is rabbetted to the bottom (flat) side to provide clamping room.
The jig is clamped to the workpiece, with the angled end lined up with the end of the workpiece. A 3/8" bit and 1/2" guide bushing is used on the router, and run down the slot in the jig to form the pocket hole.
I was trying to reverse the process for table operation, but then my brain exploded
Frank Hagan is offline   Top - Reply with Quote
Old 06-03-2005, 11:05 AM   #3
hawker44
New Member
Default Pocket Hole Jig
Thanks Mr. Hagan for the info. I will attempt to get the issue and check it out, I too have exploded my brain trying to figure one out for the table.
Thanks again
Old 08-16-2005, 05:11 PM   #4
tman
New Member
tman is on a distinguished road
http://www.originalfurnitureplans.co...jig/drill1.htm
tman is offline   Top - Reply with Quote
Old 08-16-2005, 07:29 PM   #5
Glenmore
Forum Moderator
Supreme Forum King
Glenmore's Avatar
Glenmore will become famous soon enough
Send a message via Skype™ to Glenmore
Thanks and welcome for the link tman. Always a good thing to put into your favorites. Also would like to welcome hawker44, Frank Hagan to the Routerforums. Great to welcome new members aboard.
Glenmore is offline   Top - Reply with Quote
Old 09-18-2005, 12:05 PM   #6
hcbph
Dedicated Member
hcbph is on a distinguished road
The drillpress plans is very similar to one I made a long time ago, still use it at times. Only suggestion is to use forstner bits else the wood moves at tiles.
hcbph is offline   Top - Reply with Quote
Old 10-23-2005, 11:19 AM   #7
sgtgrumpypants
sgtgrumpypants is on a distinguished road
I have seen the article you mentioned, it is a router table jig consisting of two plywood boxes at a 10 degree angle one box slides over the top of the first box. It has a slot in it for the a straight router bit and a stop. I believe it was in WORK BENCH magazine but i'm not sure witch issue.
sgtgrumpypants is offline   Top - Reply with Quote
pocket hole jigs.......advice please. jer760 Tools and Woodworking 14 01-05-2008 12:31 AM
Drilling large hole over small hole or vice-versa simplenik Tools and Woodworking 8 06-13-2007 08:57 PM
Kreg K2000PP ProPack Pocket Hole Jig $91 at Amazon.com evolve The Bargain Bin 1 08-20-2006 02:59 PM
Pocket Hole Jig for the Router Table bobj3 Jigs and Fixtures 4 03-28-2006 10:25 PM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 05:29 PM
