| | #1 |
| Registered User Forum Geek | Does anyone have a home-made jig for cutting small diameter circles? (Smaller than the diameter of the base itself). I have a couple trammels built from ShopNotes plans, but none of them have provisions for very small circles. Thanks. |
| | #2 |
| Registered User Jr. Member | I would make a sub base and lay out the radius of the small circle and drill the pivot hole in the base. a blind hole in the base and the work. a short dowel pin for the pivot. i hope you get what i am saying. |
| | #3 |
| Registered User Jr. Member | snowshoe Eagle-america has a small jig for 1" to 7 1/2" circles for 26$ hope this helps http://www.eagle-america.com/html/ca....asp?id=332808 |
| | #4 | |
It will cut down to as small as 1" and as large as 7" (or more if you want). It is a sub base made out of plastic with a slot for the bit (1/4"+) and slots for two mounting screws to attach it to the router. You can set the dia of the cut to anywhere in the range. You do need to put a "pin" in the workpiece for the center..... Since you are all sharp people anyone here that wants to make one take a look at the sketch and figure out your sizes and enjoy. The view is from the bottom, the hole is for the "pin", the two matching slots are for the mount screws (flat heads). This of course may not work on your router..... and yes it is for a plunge router. Ed | |
| | #5 | |
| Registered User Forum Geek | Quote:
Thanks again. | |
| | #6 | |
| Registered User Forum King | Quote:
I have also produced another jig that does NOT require the side fence attachment as illustrated. Tom Last edited by template tom; 06-04-2005 at 10:01 PM. | |
| | #7 |
| Registered User Supreme Forum King | OH I see I said "flat head" I ment "pan head"..... sorry about that Ed |
| | #8 | |
I have an M12V so that looks like a pretty handy solution also. Thanks much. | |
| | #9 |
| Registered User Forum Geek | Hi Tom I'm a little behind on reading the posts, but curious about this jig of yours. Could you please explain it a bit more, I can't quite figure out how to use it. I do have the Hitachi M12V and would like to make small circles. Also what bit do you use? Thanks! ~Julie~ |
| | #10 | |
The side fence attachment was used for the original Circle cutting Jig This was secured to the base board 300mm x 160mm on the underside is inserted the fulcrum pin into 'Tee' nuts There are four nuts where the fulcrum pin can be re-positioned to give a great variety of circles. This has worked very well for me over the past 20 years Tom | |
| A small shop "addition" | Hamlin | Hamlin's gallery | 2 | 03-28-2008 07:07 PM |
| Gifkins small cutter diameter | S Bolton | Jigs and Fixtures | 17 | 11-29-2007 01:05 PM |
| small pieces | fishlore | Table-mounted Routing | 58 | 11-21-2007 08:23 PM |
| routing small pieces | zxxer12 | General Routing | 9 | 03-21-2005 04:40 PM |
| Small diameter circles. | NewMontanaWorkshop | Portable Routing | 11 | 10-05-2004 11:25 PM |
