| | #1 |
| Registered User Jr. Member | Hi again Since my last post was lost I am taking this oppertunity to once more post my question' First I would like to thank all those who replied to it. What I am looking for is a plan for a jig to make shelf holes The one I am thinking of is one that I saw on a woodworking program (not sure which one) it requires the use of a router with a collar (I think it is a 1"not sure) and a bit. If anyone out there can help me I thank you TonyC |
| | #2 |
| Registered User Forum Fanatic | That sounds like the jig Norm uses in New Yankee Workshop. It is made from plywood (1/2") with equi spaced 5/8" holes to take a 5/8" collar on the router and a bit to suit the shelf supports. He has pegs to locate the jig to the edge of the wood and a centre line to locate the jig from either side. He has used a shop bought jig as well as one he made himself. He showed how to make an improved model on one of his shows on making jigs for the workshop.
__________________ Dewy support team at Paltalk voice chat program Last edited by Dewy; 07-08-2005 at 02:40 PM. |
| | #3 |
| Registered User Dedicated Member | Try this one http://www.woodworking.org/WC/GArchi...23holejig.html It sounds like the one you're talking about. Looks simple to make, yet effective. Good luck, Jeff |
| | #4 |
| Senior Moderator Supreme Forum King | Tony, The simplest jig is a piece of pegboard. Your holes will be 1" apart. Simply plunge your 1/4" bit through a line of holes. If you want to set this up for a collar use a holesaw of the size collar you desire and drill out your holes; your collar will let you quickly align for each hole. You can develop end guides like the ones in the post Jeff made. Dewy hit the bullseye by saying the jig you saw was Norm's. You can get plans for Norm's jig at the New Yankee web site.
| | #5 |
| Registered User Jr. Member | Thanks to Dewy, Jeff and Mike I will be looking into all of the above Thank you again Tony |
| | #6 |
| Registered User Forum Geek | |
| | #7 | |
| Registered User Jr. Member | Quote:
Tony | |
| | #8 |
| Forum Moderator Supreme Forum King | Thanks for the link fibertech added it to my list of favorites. Always looking for plans.
__________________ Glenmore Days without wood working are days not worth getting up for. |
| Shelf pin hole jig - reviews and router solution | Greg_R | Jigs and Fixtures | 7 | 12-30-2007 07:18 PM |
| Which hole pattern should I get (plate for a Bosch 1617)? | Nickbee | Table-mounted Routing | 1 | 11-23-2007 07:49 PM |
| Drilling large hole over small hole or vice-versa | simplenik | Tools and Woodworking | 8 | 06-13-2007 08:57 PM |
| Adjustable Shelf Hole Template | SkyKing | Portable Routing | 13 | 03-30-2006 01:48 PM |
| Routing a hole | Learning Herb | Tools and Woodworking | 11 | 03-20-2006 05:29 PM |
