Thread Tools Display Modes
Old 08-09-2005, 02:25 PM   #1
normcatalunya
New Member
normcatalunya is on a distinguished road
Default Dovetailing thick material?
Hi All.Got a stots jig today and have been playing with it.Am I correct in thinking the max. thickness of wood I can dovetail is detemined by the cutter length?(13/16" as supplied)Sounds a bit obvious ,but until now I hadn't appreciated the point as the material/project I was hoping to use it on calls for 25mm(1").Have I got the longest cutting edge of dovetail bit or are there longer.A quick Web Search didnt show anything.Wouls appreciate your comments.Ta in advance.Regards.Norm
normcatalunya is offline   Top - Reply with Quote
Old 08-09-2005, 04:12 PM   #2
delroy33
Supreme Forum King
delroy33's Avatar
delroy33 will become famous soon enough
Yes that would be max for through dovetails, but 1/2 blind depends on the dovetail fixtures thickness capacity.
roy
start square, finish square
delroy33 is offline   Top - Reply with Quote
Old 08-11-2005, 01:03 PM   #3
Jigboy
Jr. Member
Jigboy is on a distinguished road
There are home made jigs for using the table saw, where the thickness would be less of a concern. It was in Pop Wood recently if memory serves. I think the guy's last name is Enger, has a book or two in the pop wood set. The jig looks easy enough, I know this is the router forum, please don't kick me.
Jigboy is offline   Top - Reply with Quote
Old 08-13-2005, 12:56 AM   #4
kesac
New Member
kesac is on a distinguished road
Rabet your boards down to 3/4, and dovetail those ends together. The Stots jig is a good thing. It is limited by the length of your dovetail bit.
Try cutting your dovetails on a table saw. That works easier than most jigs.
kesac is offline   Top - Reply with Quote
Stiff 1/4” material for a coping sled? Nickbee Jigs and Fixtures 16 11-13-2008 11:42 PM
template routing 2.5" thick material Mcgyver1 Table-mounted Routing 9 01-06-2007 10:13 PM
Template Material CCRT General Routing 6 08-11-2005 01:35 AM
Table Top Material rh111 Table-mounted Routing 4 04-19-2005 04:35 AM
Material For Router Fence kvc Table-mounted Routing 7 10-11-2004 08:52 PM
