Thread Tools Display Modes
Old 09-21-2004, 08:07 PM   #1
paulcomi
Sr. Member
paulcomi's Avatar
paulcomi is on a distinguished road
Default What jigs do you find most useful?
I have a shop built router table and other than a pair of guide blocks I made for my clamp n tool to accurately position it for cutting dado's etc as well as the two hold down sleds I made for securely holding cope and stick pieces I don't really have any jigs for my router. What jigs do you find useful to have?
paulcomi is offline   Top - Reply with Quote
Old 09-22-2004, 02:54 AM   #2
ejant
Router King
Supreme Forum King
ejant's Avatar
ejant will become famous soon enough
Circle cutting jigs and other I have made to suit thier purpose. Like three different jigs for making wooden hinges. This I do with an Incra table. Another for a cutoff saw for pen blanks.
ejant is offline   Top - Reply with Quote
Old 09-22-2004, 11:35 AM   #3
kp91
Forum King
kp91's Avatar
First Name: Doug
I typically use circle jigs, but I also use a lot of one-off templates for unique projects. For example, I just finished a project that had a bunch of window and door cut outs. I drew the shapes I wanted on Autocad, scrollsawed them out, and mounted guide strips on the template so that all windows were indexed to the exact same spot on each side without having to measure.
I've used home-made radius jigs for putting 3" radius curves on a bunch of shelves, etc.
1 John 1:9
Old 09-23-2004, 12:38 AM   #4
template tom
Forum King
Jigs and templates play an important roll in my workshop as they introduce a greater safety awareness when using the router. I have jigs for cutting mitres inseting mortices inserting all sorts of hinges routing elliptical boxes and picture frames. routing with jigs and templates and template guides add safety and confidence when routing. I do volunteer work at the local guide dog association where blind people come to do some woodwork and I introduced them to the use of the router once I have produced the templates and jigs for them.
Tom
Old 09-23-2004, 11:28 PM   #5
paulcomi
Sr. Member
paulcomi's Avatar
I'd like to learn how to make templates for cutting hinge insets for cabinet doors. Do I need a set of template collars for my router base or can I use another method? I actually bought a set of them but returned them after I figured that I would have to allow for the collar width and thought a pattern cutting and flush trim cutting bit would be easier to use.
Old 09-24-2004, 02:22 AM   #6
template tom
Forum King
Default Jigs and fixtures
I assume you are talking about 'Butt' hinges for the doors. This will require a template guide (template collar) and a straight cutter. I do not see how it would be possible to use 'flush trim bit' to take out the recess. Template guide is the easier method.
Tom
Old 09-24-2004, 08:19 AM   #7
squattybody
New Member
squattybody is on a distinguished road
I have an Incra Jig LS Super System which allows me incredible flexibility and accuracy. The instruction videos and design books are very good. I also have the spacer jigs as you can find on the Oak-Park sight. They are quick and easy to use once set up. Another that I acquired recently is the Spirocrafter and I expect to be able to do some beautiful work with it. I have made a sled for my shaper table and am in the process of making a circle cutting jig(Norm's version). Like someone said on another forum, I think making jigs are as much fun as the projects they are made for.
Squatty
squattybody is offline   Top - Reply with Quote
Old 09-25-2004, 02:45 AM   #8
paulcomi
Sr. Member
paulcomi's Avatar
Is there a quick n dirty way to laying out and making templates anyone can share? For ex, with a jig for cutting out recessed hinges, my inclination is to lay a hinge on a piece of paper, somehow factor in the width of the collar, cut out the layout and trace it onto a piece of mdf and then cut out the shape with a jigsaw and clean it up with an oss. Is that how its done? What's the hot tip for incorporating the width of the collar?
Old 09-25-2004, 06:18 AM   #9
rout-on
Dedicated Member
rout-on is on a distinguished road
I think what he is asking is step by step procedure for inserting hinges into mortises making templates( hinges vary in size,thicknesses,width,etc.) so you will have to make seperate templates for each one........... and basically trial and error with using them.I guess,I by no means am AN expert,just what I saw being done.
rout-on is offline   Top - Reply with Quote
Old 09-25-2004, 06:19 AM   #10
rout-on
Dedicated Member
Impressive indeed template Tom,do you have larger images of those posted........
Oak Park box-joint jigs for dovetails - please help duckarrowtypes Jigs and Fixtures 20 04-06-2008 09:38 AM
what's a good router yo buy for working w jigs? patrick miles Introductions 4 12-18-2007 06:43 AM
Planer Jigs.... challagan Tools and Woodworking 7 09-30-2007 12:09 AM
Jasper Circle jigs for Router cassiusclay Jigs and Fixtures 5 05-21-2007 08:40 PM
oak park tenon/coping jigs ShaneB Table-mounted Routing 5 04-20-2006 12:22 AM
