| | #1 |
| Registered User New Member | I have a Porter Cable router and I was trying out a new bit tonight. Something must of happened when I was trying it out on some soft wood to tight the chuck down. I can't get my chuck loose to get the router bit out. I have spent nearly two hours trying. Any suggestions. Will my Router be damaged AKA misaligned in someway , can the spindle be bent? I tried not to bend or heave on the spindle just on the chuck. Help! Also How can I check to be sure it is straight once i do get it out, I do a lot of countertop work. |
| | #2 |
| Forum Moderator Supreme Forum King | hammernail did you try turning the colect right of the shaft. It sounds like you could have a burr or maybe over tightened it. You should be able to get the nut off the colect side and tap it out from underneath.
__________________ Glenmore Days without wood working are days not worth getting up for. |
| | #3 |
| Registered User New Member | i had to send it in for repairs. Several guys tried to get it loosened up at Home Depot where I bought it, even using wrenches and couldn't do it. So I am with out a router for 4 to 6 weeks. I didn't even over tighten when I put the bit in. I hope the repair people put it back in working order and make sure everything works OK. |
| | #4 |
| Registered User New Member | It might be the same thing my daugher did to mine, last Christmas "saving money" making gifts! She didn't tighten it enough! and it sorta melted together - had to replace parts (would have been way cheaper to buy the gift - but not as much fun?) |
| | #5 |
| Senior Moderator Supreme Forum King | Hammernail, Take the time to read the many posts on proper collet adjustment. There is a lot of good information which will help in the future.
| Porter Cable Motor Stuck | LarryP | Introductions | 4 | 10-16-2006 05:03 PM |
| Stuck Bits | ARTEDNA | Introductions | 2 | 06-10-2006 03:52 PM |
| Bit Stuck in Chuck | Zuki | Tools and Woodworking | 2 | 09-09-2005 05:47 PM |
