my copy carver - Router Forums
post #1 of 22 (permalink) Old 08-27-2009, 01:56 PM Thread Starter
First Name: darren
Default my copy carver
just thought id post a picture of a copy carver ive built ,its crude, i could do with a little more patience.
teething problems so far with it are.. i fabricated the blue rails way to high.
the pillar bearings on the turn tables are sloppy,i should have used two sets of these instead of a pair and used box section instead of plate as the chain cranks have play in them.
im not sure whether to remedy this or do away with the turn tables all together i had the mind to just remove them when a project called for it then refit when ever i wanted to copy a stock..but im now thinking why cant i just lay the stock down flat with the blank placed down next to it and carve it out that way then flip them just like the guitar builders do.
im sure i,ll get there in the end and will probably end up scraping much of what you see.
any suggestions welcome
shoot is offline
post #2 of 22 (permalink) Old 08-27-2009, 02:27 PM
Mike Wingate's Avatar
First Name: mike
That is a good effort. Improvements can always be made. A good start. B+
Mike Wingate is offline
post #3 of 22 (permalink) Old 08-27-2009, 07:56 PM
CanuckGal's Avatar
First Name: Deb
I applaud your ingenuity. I am sure you will iron out any bugs as you go along.
I measured, I marked, I cut.
CanuckGal is offline
post #4 of 22 (permalink) Old 08-28-2009, 06:15 PM Thread Starter
First Name: darren
Thanks folks theres a bit to change on it but when i finally get useing it trouble free i,ll update the thread.
shoot is offline
post #5 of 22 (permalink) Old 08-29-2009, 01:36 PM
First Name: Harry
You are off to a good start. I would recommend you use CNC Router Linear Guide Bearings. I have seen them on eBay (4 for under $50) You will never get all the play out of what you have. If you make a few different size stylus, with smaller cutters you can do finer details. keep us up to date.
Harry, TX
Cut it twice, and it's still too short!
Old_Chipper is offline
post #6 of 22 (permalink) Old 08-29-2009, 04:56 PM Thread Starter
First Name: darren
thanks for the advice old chipper i,ll look those up, im waiting on some of those sabburrs to turn up with matching stylus kits.
im looking forward to useing it.
shoot is offline
post #7 of 22 (permalink) Old 09-13-2009, 11:21 AM Thread Starter
First Name: darren
Default improvements
its coming along nicely i decided to make the rail that holds the router and stylus holder flexible if needed,it can be locked off in any position.
however id like to do away with this router and the way its assembled.
hoping some on here maybe able to help with that.
since only recently coming across a supply of round bodied routers im looking for a suitable clamp or router body collar like the one in the link below.
is there anything out there off the shelf that anyone knows of?or something suitable? thanks all, daz
YouTube - Gemini Wood Carving Duplicator
shoot is offline
post #8 of 22 (permalink) Old 09-13-2009, 12:31 PM
Gap_308's Avatar
First Name: Scott
Very cool. You get an A+ for the rifle stock. I like the bike sprockets.
Thank You Veterans
Gap_308 is offline
post #9 of 22 (permalink) Old 09-13-2009, 01:16 PM
CanuckGal's Avatar
First Name: Deb
Don't know if this will work but Lee valley makes a motor mount that sounds like something you are looking for.
Motor Mount - Lee Valley Tools
post #10 of 22 (permalink) Old 09-27-2010, 06:44 AM
hal37880's Avatar
First Name: Hal
Default copy carver
Great job on your duplicator. How about some photos of your finished stocks? I also carve rifle stocks.
Hal
hal37880 is offline
Human Verification
Wanted: copy of manual for Sears Dovetail Jig 25450 (or 25455) syauch General Routing 7 05-20-2012 11:12 PM
fish carver ed something shoot Pyrography and Carving 5 08-20-2009 08:58 AM
finding a mortice pal copy DJeansonne Jigs and Fixtures 1 03-30-2009 12:19 AM
CMT 3D Router Carver jms1226 General Routing 4 04-07-2008 12:13 AM
