Thread Tools Display Modes
Old 09-24-2004, 01:05 PM   #1
Davewillen
Davewillen is on a distinguished road
Red face Wooden Clock Gears
I build wooden clocks. I cut the gears out with a scroll saw. Because of the repititious nature of the gear teeth valleys I've been trying to figure out how to do that on my router. I built a jig similar to one I use for finger joints to get the spacing correct and that seems to work ok. I just haven't found the correct bit to use. I've also done it on a table saw but the valleys are then just straight without any slope to them. Sure would like to find a way to do it on the router. Maybe one of you geniuses have done this and would be willing to help me out.
Dave from Bouse
Davewillen is offline   Top - Reply with Quote
Old 09-24-2004, 03:16 PM   #2
ejant
Router King
Supreme Forum King
ejant's Avatar
ejant will become famous soon enough
Sounds like you could try a spiral bit.
ejant is offline   Top - Reply with Quote
Old 10-06-2004, 12:02 PM   #3
reible
Supreme Forum King
reible's Avatar
Dave from Bouse
Did you ever solve your problem and figure out how to do the gears?
Ed
Old 10-06-2004, 06:15 PM   #4
template tom
Forum King
Dave from Bouse
This is something I have never done with the router but the challenge is there for someone and maybe one day I will get round to trying it. One thing is clear you will need to work with a small template guide and a small cutter. One of the problems would be making a number of templates to suit the various sizes of teeth, and setting up a means of rotating the blank and positioning. The list just goes on and on
Tom
Old 10-10-2004, 10:48 PM   #5
Dewy
Forum Fanatic
Dewy's Avatar
Dewy is on a distinguished road
My working life has been 30 years as a tool maker making dies for aluminium extrusions.
I worked on mills for most of the time and have sometimes used small engineering milling cutters in my router.
The 3 flute spiral milling cutters cut wood beautifully and clear the swarf easily.
The standard cutters for die milling have 4 flutes and a 3/8" shank with a 3° or 5° angle.
The cutters are measured by the tip diameter with the smallest being 3/32" and the normal sizes being 1/8", 5/32" and 3/16".
The shortest cutters have a 3/4" cutting length but it may be possible to use such cutters to produce gears with a 3 or 5 degree edge.
A 3/8" collet would be needed.
With only a 1/4" router I have only used 1/4" cutters for making a slot in bread board edges.
Set in a table with a feather board these milling cutters make short work of that job.
Dewy
support team at Paltalk voice chat program
Dewy is offline   Top - Reply with Quote
Old 01-04-2007, 11:36 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Dave
I know this is a old post but if you didn't find a router bit to use give this one a try, it's a great bit and you can use in a small router or a trim router.
WhiteSide Carving Liner Bit
SC50 and the BCR062 bit
http://woodworkersworld.net/carving_...bit_bits.shtml
It's the same type of bit that Sears is now using in their new computer carving machine that sells for 1900.oo dollars and runs CarveWright software and looks like a 14" planer or to say a CNC machine.
If you have the bucks the new Sears machine will cut your clock parts out quick and easy.
Craftsman CompuCarve Compact Woodworking Machine, Computer-Controlled
http://www.sears.com/sr/javasr/produ...TOOL&ihtoken=1
To see a demo video of this great machine, see link below ▼
http://www.carvewright.com/
This is now on my wish list and I'm going to get one as soon as I rob bank
just kidding but I'm going to get one.
The real neat thing about this tool I don't need to have the computer in the shop, just need to but the items I want to make on a memory card then just put it in the machine.
And with Opt. Scanning Probe (299.oo item) I can copy anything that's fits in the machine and put it on the memory card so I can make as many copies as I need to or resize them on the PC.
Dave ,like parts for a wooden clock
Just a NOTE**** you can download the software to have a look see BUT it's a big file 63mb. but the the machine comes with a cd for the software install.
Bj
wooden-clock-gears-liner-bit.jpg  wooden-clock-gears-sears_carver.jpg  wooden-clock-gears-sears_1.jpg  wooden-clock-gears-sears_2.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-05-2007, 11:58 AM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Just a update on this great machine, and I found a great video to show how it works.
You can see a video demo at this site below and also order it from them if you want, Sears is on back order.
Besure to check out the
Gallery
http://www.carvewright.com/forum/vie...262db36c9bd661
and the Fourm
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-05-2007, 05:34 PM   #8
kp91
Forum King
kp91's Avatar
First Name: Doug
Woodline USA has a whole series of gear patterns for wooden clocks.
1 John 1:9
Old 02-06-2007, 11:01 AM   #9
tbohacek
New Member
tbohacek is on a distinguished road
I saw the carve wright machine at Sears and also read a lot of the reviews on line on the factory forum. It seems there are a number of issues, including the flexible shaft. Does anyone have one of these machines and how well it is working. I am ready t orob the bank, but do not have the patience to help work out the bugs. BTW, Sears had it on sale for about $200 off
tbohacek is offline   Top - Reply with Quote
Old 02-06-2007, 10:43 PM   #10
rmaxa
Forum King
rmaxa's Avatar
First Name: Rolf
rmaxa is on a distinguished road
I've seen this at Sears, and it looks great. However, doesn't it taken something away from the project if it's made by a machine. It's doing all the work for you, all you have do is glue the parts together. I'm not a wood carver, but this may be going to far. Don't get me wrong if I could get one I would. I'd like to think of myself as a purist.
rmaxa is offline   Top - Reply with Quote
lettering into wooden signs- HOW? moe Project Plans and How To 16 09-19-2008 10:49 PM
Modification to Apricot clock harrysin Woodturning and Lathes 4 06-03-2008 01:23 AM
MDF Kitchen wall clock bobj3 Show N' Tell 40 05-18-2008 03:46 AM
Routing Wood Clock Gears. Wes Anderson Introductions 5 10-27-2007 12:22 AM
Engraved wooden sign. -Sam- Portable Routing 12 12-29-2004 12:01 PM
